Has Pro Tools 11.3.1 helped?
Before I install 11.3.1, has anyone seen this update solve any problems you are currently having? The Read Me file doesn't seem to address many solutions to current issues.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Re: Has Pro Tools 11.3.1 helped?
- Video Engine would hang when attempting to enable - Erratic behavior when moving clips around in the Edit window. It appears that 11.3.1 solved both problems ... -paul. |
I have constant crashes when using VIs in 11.3.1 again….
Especially when looping a part and letting play….after 7-10 minutes crash!!! This happens from 11.2.2 and so….. Back to 11.2.1 once more….. If you guys have time please check this…open some VIs,make a loop and let it play…see if it crashes after 10 minutes or so…. This MUST be fixed ….. a lot of users are having the same problem (among others) |
When I have time I'll give this a test. I don't do many Vi's, but was doing some tests yesterday on my test rig and have gotten multiple hard crashes from changing VI's. This happens with as little as one Instrument track with one VI loaded. Maybe I'll try going to 11.2.1 for Yosemite, otherwise I'm going to go back to testing on Mountain lion.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
A suggestion, if I may...
Use one of the Avid VIs for your testing to help insure the problem is not related to a 3rd party VI...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
11.3.1 have a lot of good stuff. Video engine is much better and pro tools performance is better. Well worth the update.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Oh well ... I should try that ... I thought Yosemite was the problem ...
System Details: iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz Macbook M2 Pro macOS 14.4.1 Pro Tools 2024.3.1 Logic Pro X Reason 12 UA Apollo 8p Apogee Thunderbridge/Apogee Symphony I/O 2x6 Eleven Rack/Focusrite ISA Two/Onyx 1640i UAD Satellite Quad MOOG Mother 32 Nektar Panorama P1 Axiom AIR 49/Axiom 49/Yamaha P35 Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e Genelec 8040b/Yamaha HS80s/M-Audio BX5a Beats Solo/Shure SRH1840/Slate VMS https://open.spotify.com/artist/7KfV..._branch=1&nd=1 |
I have made an older post about this….I thought it was omnisphere but during tests i found out that crashes happening with other VIs as well….
Crashes began from 11.2.2 and later… Pretty sure this is a major bug and not my system or a a faulty plugin…tested everything …this happens also to my clean test drive with 10.10.2 (tested also on 10.10.0 and 10.10.1) If you guys making the test..load some VIs that you would in normal conditions when making a song or whatever…means that for example load an omnisphere if you have ,ssd4,kontakt etc etc…and let it loop for a while…. |
You guys helped once, please help again: swirling noise | 11R Newbie | Eleven Rack | 22 | 06-24-2012 04:42 PM |
Thank you to all who have helped today.... | stevegrisham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-15-2004 02:02 PM |
HELPED NEEDED PLEASE | CHRS | Tips & Tricks | 3 | 10-30-2003 07:37 PM |
How can you penalize who helped you grow? | MAXIMUSIC | Pro Tools TDM Systems (Mac) | 33 | 09-17-2003 07:05 AM |
To all who have helped: thanks & hallelujah!! | athlone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-11-2002 09:48 AM |
