#31
Re: Ready to pull the plug. Yup - another goodbye post
I agree. I ran Sibelius and Protools on an i7-8700K CPU @ 3.70GHz. I had to set the buffers to 256 or 512 samples to get smooth playback. Some cores were maxed out while the rest were barely measuring 10%. That wasn't good when Sibelius, Protools and my midi performance needed to sync up. My Command8 didn't work with the motherboard.
Also, tried that trick where you start up Protools and set the affinity from the command line. I even purchased Process Lasso in order to better manage load balancing. I just ended up proving to myself that Protools hasn't been optimized to leverage newer CPUs with Windows. In my opinion, it needs a rewrite on Windows. The one thing that I'm quite certain of is that Protools performance improves more due to more GHz single core performance on new CPUs vs higher thread counts. There is a very real bottleneck in the Virtual Instrument plugin mechanism with respect to Windows. If you watch the performance counters it's obvious that Protools isn't spreading out the processing to all available cores. One or two cores are pegged near 100% while all of the others are way down with some below 30%. The system usage meter in Protools looks like a triangle instead of a wavy line. Folks here manage to get a stable system using I3 and I5 machines but I'm quite certain the Virtual Instrument count is low in comparison to the straight analog processing. Appreciate the feedback and best of luck with your career. Sounds like you're living the dream with that work you do. Cheers! Alain P.S. re. 2021.3 got the graphics problem resolved. Had to override DPI scaling and set it to "System". P.P.S Midi isn't working for some reason.
6 Core Intel Xeon X5690, 4200 MHz P6T DELUXE V2 (BIOS 1202 ) 24GB DDR3, GeForce GTX 1060 3GB SSDs, Windows 10 Pro 64 Bit 10.0.19042.867 Protools 2020.12, Studio One V5.2, Sibelius Ultimate 2021.2, VSL Command8, Motu M4 |
#32
Ah, glad you mentioned buffers! With VIs in the mix it's pretty damn near impossible to work with 32 or 64 buffers. I always use 256 as a minimum and with big sessions I go to 512. This doesn't bother me at all. If I didn't do this, I'd get plenty of errors too.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
#33
This is the Longest Goodbye Ever
Maybe we talked you into rethinking leaving ....
#34
Parting is such sweet sorrow
Simon2065 Pro Tools Ultimate 2023.12 Win 10 Pro 22H2 Gigabyte GA-Z270 i7-7700K 32GB Ram UAD Apollo 8 |
#35
I recently bought a refurb Windows machine with 24 cores of Xeon and 64 GB of RAM for less than $1000. Big orchestral templates, no hitches at HWB of 64 using an old Firewire interface. It's not that expensive these days to get what you need.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Eleven Rack - Ready to Pull Trigger but: | mrgroovy | Eleven Rack | 9 | 05-31-2011 07:07 AM |
Eleven Rack - Ready to Pull Trigger but: | mrgroovy | Eleven Rack | 6 | 05-27-2011 06:37 PM |
PT9 - ready to pull the trigger, but? | Darney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-01-2010 03:43 PM |
READY TO PULL MY HAIR OUT!! *MIDI Question* | carrow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-03-2005 03:06 AM |
HD for Post, is it ready yet? | mazuroo | Pro Tools TDM Systems (Mac) | 15 | 07-12-2002 09:29 AM |
