Sessions Open Terminal?
Hello there
im currently working on a Mac g5 Dual 2.5 Ghz, 4Gb ram. Also Have Pro tools 8 and Digi Rack 003. I used to work on Pro tools 6.4 Le , and upgraded. I Transferred all my sessions To the New Mac. However, i cannot open any Sessions.When i Click on the file the Terminal opens up.Most of the sessions where made with midi, so would there be a way of recovering the sessions or at least the Midi? thanx- |
Re: Sessions Open Terminal?
Hi.
You should be able to open PT6 sessions in PT8. Just launch PT, go to "open..." in the file menu, and navigate to a PT6 session file. It should open. To fix the problem you describe with session files opening Terminal, do the following: - select a PT6 file in the finder - select "get info" from the menu - Change the "Open with..." to PT8 - Click "change all..." - OK From now on they should launch PT8 when you click them in the finder. IHTH. |
sorry but it didnt work =[
"sorry but it didnt work =[" doesn't really tell anyone anything.
When you go to File>Open Session in pro tools can you not find your files? When you try to open one, does Pro Tools give you an error? What's the error... help us out here. Will
http://soundofthatday.com |
Cannot open PT9 Session in PT10 - ""could not complete the open sessions command..." | median | Pro Tools 10 | 5 | 10-01-2013 11:14 AM |
sessions always open with mix window track list open | jaglance | Pro Tools TDM Systems (Mac) | 2 | 08-03-2009 06:03 PM |
PT 8 with Avid Fibre Mgr 5.1 WILL NOT Open let me open Sessions! | chanlon25 | Post - Surround - Video | 4 | 03-03-2009 10:11 AM |
terminal /bin/bash interaction with pro tools | queue | Pro Tools TDM Systems (Mac) | 0 | 12-06-2006 01:07 AM |
SampleTank terminal blues...please help | sabayachi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-06-2005 04:15 PM |
