Avid Pro Limiter Vs Flux Limiter
I bought the Flux limiter because the special price, but in my opinion the interface o the flux is not that great, so I then tried the Avid Pro-Limiter (they are both DSP). I much prefer the Avid Pro-limiter in most ways! I am only using it to catch any inter sample peaks so it is a very gentle use (just in case there are IS peaks), the interface and ease of set up of the Avid is much better than Flux. So I bought the Avid limiter!
Re: Avid Pro Limiter Vs Flux Limiter
Avid pro comp is real nice / real quick and clean
I was impressed
A while ago I tested a few true-peak limiters and ended up with Avid pro-limiter. Nice and clean, works great on a great variety of sources.
my blog:Tamas Dragon |
I have the pro limiter and Flux elixir. I like both but use the Flux elixir most of the time. It is very transparent and more practical. I like the fact that you can control the peaks without actually touching the average loudness at all. For example, you can lower the peaks on 2 or 3 small sections of a printed mix (in audiosuite) without any loudness change at the in and out location of the processed regions. It is a really good tools for fixing QC problems.
But... Their support suck be time.
Serge Hamel Mixer / Sound Designer http://www.netpostproduction.com http://immersivesoundvr.com/ |
I agree, the Cedar adaptive limiter is great. That's my #1 choice plugin to make SFX punchier in audiosuite. The 12,000 samples delay compensation needed when using it in realtime make it less convenient when mixing.
I use the Cedar whenever I want to limit peak and increase the average signal level both at the same time and the Flux elixir when I want to reduce the peaks without altering the perceived loudness. I heard good stuff about the Nugen but like you, I like using AAX DSP PI whenever possible.
Flux Solera V3 AAX and Pure Limiter V3 AAX | Stereo Missile | AAX Plug-ins | 0 | 12-22-2013 02:22 PM |
Flux Pure Limiter II - need help | el biciclista | macOS | 0 | 10-11-2012 09:50 AM |
FS : Flux Solera, Pure limiter and Syrah, Avid Reel Tape suite, and Transfuser 1.1 | Roll | Buy & Sell | 3 | 06-05-2012 04:37 AM |
LImiter on audiotrack Vs Limiter on auxiliar track | cinetj | General Discussion | 2 | 07-15-2008 11:15 AM |
Waves L1 limiter vs. Focusrite D3 limiter??? | Danny Caccavo | Pro Tools TDM Systems (Mac) | 1 | 05-01-2000 12:14 AM |
