Timecode readout missing in LE window
Just upgraded to 7.3.1 PT LE on G5 Dual 2 PowerPC, which I just upgraded to 10.4.11. All was fine till I suddenly lost the time-code reference in top window of session.. ilok working fine, can still import & open OMF. Reinstalled both PT & OS. Uninstalled recent apps, Missing Sync, Office 2008 & PPMulator. New Mouseworks turbomouse, but it seems to be working fine. Any ideas out there of what to try next?? Thanks. rg
Re: Timecode readout missing in LE window
In the Edit window, below the Shuffle, Spot, Slip and Grid buttons, you'll see 2 icons in the black bar - click on the one second from the left and make sure that 'Timecode' is checked.
Thanks, checked it and minutes/seconds is selected but grayed out
ps. would the fact it is grayed out be part of the issue why it is not reading?
Philip Perkins |
DV toolkit seems fine, omf imports & opens fine. I'm stymied.
OMFs are handled by DigiTranslator so it might be the the Tool Kit part got boogerd but DigiTranslator is OK
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Thanks, any idea how I can check DVtoolkit is working other than re-syncing at ilok?
Just in case you weren't aware, the original DV Toolkit only worked on versions 6 (.4 if I remember rightly) up to version 7. From 7.1 DV Toolkit 2 is required. You can upgrade from the original DV Toolkit and you gain a bunch of goodies including 48 mono or stereo tracks, continuous scrolling, Digibase pro, full import session data, video editing & assorted plugins etc. This might explain why you are still able to open OMF's but not use other DV toolkit features. Or I may be way of target . |
Upgraded from 7.0. Will try this Monday, hoping this is the brilliant solution I need. Thanks.
Avid Mojo HD Timecode Window Option??? | The Mix | Pro Tools TDM Systems (Mac) | 2 | 06-05-2008 07:53 PM |
TimeCode window burn | Tomio Broman | Pro Tools TDM Systems (Win) | 0 | 11-08-2006 02:36 PM |
edit window & timecode freezes intermittently | zerovu | Pro Tools TDM Systems (Mac) | 1 | 06-15-2006 08:12 AM |
DV capture out of sync when lined up against PT timecode window | loopengine | Pro Tools TDM Systems (Mac) | 5 | 06-14-2003 04:53 PM |
Ruler view´s missing timecode....???? | Sven-Gunnar Petersson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 12-20-1999 04:42 PM |
