outputs vs sends for mixing down within pro tools
i have been playing around with mixing down within pro tools before bouncing to disk and i was wondering if it was more preferable for any reason to do that with outputs or sends and if there would be any difference in the end result
scenario 1: 1. create and record enable a stereo track with a stereo bus input (bus 7-8 for example) 2. change the output of all the tracks pointing to standard out 1-2 to bus 7-8 3. record scenario 2: 1. create, record enable and mute a stereo track with a stereo bus input (bus 7-8 for example) 2. add sends: bus 7-8 to all tracks that are also outputting to standard out 1-2 3. record
-roark MacBookPro/OSX.10.6.4 Mbox3pro/PT-9.0.1 |
Re: outputs vs sends for mixing down within pro tools
You can check situations like this by mixing down using both methods and inverting the phase of one mix to see if they null to silence. |
Some outputs and sends were made inactive? | ZombiesAreJerks | macOS | 1 | 04-27-2013 04:26 PM |
loosing sends wet/dry while mixing | amoretam | macOS | 9 | 02-12-2013 05:35 AM |
sends vs outputs | pinnacle | Pro Tools 10 | 6 | 09-04-2012 05:36 AM |
sends mixing? | tracktensionrecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-10-2008 07:26 AM |
Sends Vs. Outputs | 3Dbuddah | Pro Tools TDM Systems (Mac) | 0 | 06-21-2003 04:28 PM |
