Audio Different When Bounced
I edit a radio show and receive each month's show on a DAT, record them into Pro Tools 6.9.2 with my MBox, edit the shows and then bounce them to the disk as MP3 files. I've noticed lately that the shows will sound fine in Pro Tools, but after I bounce them the show host's voice is much deeper, like it's playing slower. My knowledge of Pro Tools is very basic beyond simple importing, editing and bouncing, so I may be missing something fairly easy...
I record audio in as an SD II file at 44.1kHZ with a 16 Bit depth and +6dB fader gain (I don't know if that info is useful...) |
Re: Audio Different When Bounced
I don't use PT for mp3. I import my full bit/samplerate AIFF bounces into iTunes for mp3 conversion. |
I tried bouncing the audio as an AIFF file, but again, it sounded fine in my headphones when it was bouncing, but when I played it in iTunes, the voice was still deep. I tried changing my conversion quality from better to best with no luck. Any ideas?
Your dats are probably 48kHz. You're transferring in locked to the dat's clock at 48k but with your PT sample rate set to 44.1kHz, that means your audio is being tagged with the wrong sample rate. When you bounce, it's not actually running any conversion down on the sample rate so when you play it back, it's like playing back a 45rpm at 40rpm.
Set your session sample rate correctly in the future and you won't have any more problems. |
Bounced audio is off from midi? | koka | Pro Tools 11 | 1 | 03-11-2014 02:11 PM |
Bounced Audio DOWN -1 SEMITON?? | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-11-2012 09:53 PM |
no audio in the bounced audiofile ! | wmcintyre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-09-2006 08:18 AM |
Bounced Audio | The Mule | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-10-2004 12:51 PM |
Bounced audio won't play | Doug Ring | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-23-2001 09:21 AM |
