Old 05-20-2022, 11:40 AM
pforbess pforbess is offline
Default Copy/Paste clip - deleting the pasted version also deletes original
1) separate clip at selection
2) copy
3) paste that to new location
4) I decide to delete the pasted clip (select and clear the pasted clip)
5) it also deletes the original separated clip
Is there some setting or different procedure for clear/delete that retains the original clip? There must be some way, I must be doing something wrong.
Thanks!
Old 05-20-2022, 11:52 AM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Copy/Paste clip - deleting the pasted version also deletes original
Are you clearing it on the track or in the CLIPS bin? The latter will remove other instances.
linkedin
Old 05-20-2022, 01:56 PM
Yes, I was clearing it in the CLIPS bin. Thanks for the info!!!
Old 05-20-2022, 02:16 PM
jeffro's Avatar
Thanks for confirming. You can right+click > Clear the Clip on the track to leave other instances.
linkedin
Copy and Paste Clip Gain issues DJ Hellfire Pro Tools 12 14 01-24-2018 10:10 AM
how to paste a clip at identical time marker as original banjo71 Tips & Tricks 13 01-21-2017 06:12 AM
copy paste clip gain Cryos Pro Tools 12 0 03-13-2016 06:39 PM
Clip gain copy/paste bug yop22 Pro Tools 10 6 02-21-2013 07:22 AM
copy-paste clip and automation data marcelkavka Pro Tools 10 2 08-13-2012 04:20 AM
