SSD4 suddenly stopped opening at all on PT10 & 11
I was working on one new song session. Then suddenly I can't open the SSD4 at all. I mean that it opens normally to plugin chain. But I can't edit the plugin. If I click the SSD4 plugin.. it crashes the PT.
I even tried to remove DPM and AAX plugins from Plugin folder and re-install them. But doesn't help. I haven't changed ANYTHING on my settings or anything.. just one evening this plugin didn't open at all. Actually if I open this plugin on other track without samples loaded.. it works. And when I put few samples there now.. it works. But when I wan't to open this SAME PATCH/preset that I worked in that session.. it always crashes. My god.. this never happened before. Anyone has the same problem?? The same problem in PT10.3.9 and in the latest version of PT11. I even tried to make completely new blank session and open that SSD4 preset/patch.. but no. it crashes the PT. This is actually nightmare. I builded so perfect drum patch there on my new song and no I can't open it at all. As you know it's impossible to do the same patch.. cause you cant remember all the samples and volume/bleed levels etc The weird thing is also that in that new session I can play SSD4 normally with that preset and right samples.. but I just can't EDIT the plugin now at all! This is so weird.. Do you have any advices? PS. I even tried to change the Memory Guard setting from High to Off.. it doesn't help. Thank you in advance! Last edited by JayRay; 10-30-2017 at 10:59 AM. |
Re: SSD4 suddenly stopped opening at all on PT10 & 11
Okay I think that the problem is solved.. for now.
I found one preset that is almost the same as the new one was. So I saved it in SSD4 by saving in the actual plugin.. on the left "Save Kit". And now I can open it without problems. But that one preset is still a big mystery why it doesn't open. But I will shout again if the problem will come back :) |
ArtistMix Connection Suddenly Stopped | Victor Kennedy | Artist Series | 7 | 09-25-2017 02:41 PM |
Playback suddenly stopped | MattyP89 | Pro Tools 12 | 2 | 03-21-2017 04:22 AM |
Video Window just stopped opening + Crossfades stopped working [SOLVED] | DBK | macOS | 0 | 02-28-2015 12:34 AM |
Pro tools 8.0.5 just stopped launching suddenly?!?! | kutkut | macOS | 3 | 11-18-2014 02:45 AM |
iLok2 suddenly stopped working...!? | Oli P | Pro Tools TDM Systems (Mac) | 11 | 11-30-2011 03:00 AM |
