Old 02-03-2006, 11:01 PM
chris lee chris lee is offline
Default protools le with protools mpower
hellow
i use protools mpower with maudio inerface/power book to record some life playing. and i am using a protools le with my mbox plus power mac at home.
I wonder if i can use protools le to open protools mpower's file?
Please someone help me
thanks
Old 02-04-2006, 07:13 AM
Shawn Simpson Shawn Simpson is offline
Default Re: protools le with protools mpower
Yes, you can.
The only consideration is if you go to version 7 on either system, you'll want to go version 7 on both so that you won't have to jump thru any hoops to go back and forth. But as long as you keep the versions comparable on both, you'll be fine.
problem pt mpower 8.0.4 windows seven 64 with low latency markolone Pro Tools M-Powered (Win) 0 10-12-2010 02:34 PM
Help big decision! Keep Mpower or go LE? Mikey Ace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-08-2008 01:05 PM
Can Pro tools le/ Mpower use 2 iloks at same time. Mikey Ace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-29-2008 06:23 AM
How do Mpower update policies work? Mikey Ace Pro Tools M-Powered (Mac) 1 09-03-2008 11:27 AM
Mpower system in local for completing LE homestudi seth666 Pro Tools M-Powered (Win) 3 04-20-2006 09:02 PM
