Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 11-07-2013, 01:22 AM
ics ics is offline
Default Setting up a Control 24
Guys i really need help setting up my control 24 which I bought from some one else.
I need to set it up to a mac pro running PT 8. I have a control 24 and I was told I need a twisted Cat 5 Cable.
Do i need down load any drivers? Any links?
Is it as simple as connecting it to the mac? Any step by step info would help me a lot.
Secondly If i wanted to use the preamps on the control 24, how could I connect this to my Digi OO2 and use them as inputs?
Currently my priortiy is using the Control 24 as a controller.
Kindly advise please. thanks
Old 11-07-2013, 03:00 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Setting up a Control 24
All drivers are incorporated into pro tools. Just connect Ethernet cable and turn on. When you load pro tools go to setup/peripherals/Ethernet controllers and you'll tick the box to scan for controllers and the control 24 will appear and select it Voila.
The preamps have outputs on 25way D-connectors, so you will need 25way D-connector to balanced 1/4in jacks. This will enable you to have another 4 mics into the 002 rack
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-07-2013, 06:26 AM
ics ics is offline
Thanks so much Chris!! Appreciate it. Will try it out this week end. Very kind of you! Cheers
Old 04-14-2023, 06:22 AM
Muziekschuur Muziekschuur is offline
Does this setup procedure still apply under the newest pro tools version musician.
BAG END gives THE BEAT!!
Old 04-14-2023, 06:50 AM
Yes, except latest version does not support it at all.
Old 04-14-2023, 07:34 AM
I plugged straigth with a ethernetcable into a Macbook Pro running Catalina and the latest pro tools Musician.
Old 04-14-2023, 09:41 AM
Please read the reply to your other duplicate thread. Control 24 does not work with any version of Pro Tools newer than 10.x
Old 01-15-2024, 01:31 PM
To fix it I bought two Mac Pro's. On one I run Pro tools 8HD. With HD3 and two 192 converters. Both machines run dual 6 core Xeon's for 24 cores and 128 GB ram. The Protools 8HD machine (A 5.1. Mac Pro) runs Mountain lion. The second Mac Pro will run Sonoma and I hope to add two 192's into a HD native card. Somewhere in the summer I hope to get PT Ultimate on that machine. So it can be attached to the 8 stereo inputs.
I allso bought V-control Pro. So I can compare the original implimentation vs V-control Pro on Ultimate.
I hope to complete this setup somewhere in the summer.
Issue setting up HUI control cytokinesis macOS 3 08-21-2012 08:16 AM
Setting up Zoom R24 as a control surface apoc64 macOS 0 01-31-2012 04:19 PM
Machine Control setting for Sony XD Cam Eric Seaberg Post - Surround - Video 3 08-19-2011 06:39 PM
Setting up ADR Studio with a Control 24 paronoff ICON & C|24 2 07-28-2005 03:25 PM
Help Setting up Machine Control 2 in OS X autopilot Pro Tools TDM Systems (Mac) 3 06-02-2005 09:15 PM
