EQ > Comp vs. Comp > EQ... when mixing
Noticed that people all do it differently. Some compress and then EQ while others (me included), EQ and then compress.
How you guys doing it?
The MPCist MSN ID: [email protected] ------------------------------------------------ R&B/HipHop/Urban/Soul/Gospel |
Re: EQ > Comp vs. Comp > EQ... when mixing
Both ways.
Depends on the situation. |
yup. Although on most outboard mixers of the lower priced variety your stuck with inserts being before eq.
Not such an issue these days is it !!
narcoman |
Post deleted by Digidesign
Since compression can behave like an EQ. ie: adding HF, cutting LF, etc. So I like to use it first and see where I'm at, and then EQ - or not. (hopefully)
With rare exceptions I'm with bassmac. The release, to me, is a great tonal control (generally the faster the brighter) and with the Distressor the mid band and High Pass detection modes, I rarely need EQ.
A good rule of thumb is do any gross corrective eq (like low end filtering) then compress and then your final fit it in the mix eq. Remember once you get your compressor set the way you want it any eq changes before will screw it up.
sm
macmandigital.com |
Yeah Steve your right compress then EQ. EQ befor will totaly change how the compresor reacts. Plus it sounds better to me anyway!
www.firehouserecordingstudios.com |
Depends on the situation. But I tend to compress then EQ. (I use outboard stuff on the mix buss).
Here's what I usually do:
subtractive eq > comp > additive eq. I'm thinking by reducing what we don't need prior to comp, we won't make any unnecessary comp. Then, I can add some high shelf for emphasizing. Just some more alternatives.
Satrio Budiono FourMix JFS Mac Studio Max M2 (2023), 32GB RAM, Ventura 13.6.4, PT Ultimate 2023.12.1, Sonnet TB2 III-D, Avid HDX 2, Sync X, MTRX Studio, Trinnov D-Mon, JBL 708P, 705P & JBL 3635 (Atmos HE 7.1.4) |
Should delay comp be on when mixing film in a studio | Moviesound | Post - Surround - Video | 8 | 07-14-2011 04:14 PM |
Mixing...Making QT ref, need help with Delay Comp | Judson | Pro Tools TDM Systems (Mac) | 1 | 11-14-2010 06:10 PM |
PSP Master comp, nearest plugin comp to Manley Vari MU? | crizdee | Pro Tools TDM Systems (Mac) | 1 | 05-22-2007 05:21 PM |
mixing and using comp in aux question | skyking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-15-2005 11:17 AM |
pros and cons of comp-eq or eq-comp | dw | Tips & Tricks | 4 | 01-28-2001 03:10 PM |
