Old 07-28-2002, 04:49 PM
PTInc PTInc is offline
Default How do i configure the 001 audio ports for cubase?
Im in the ASIO multimedia set-up advanced options for cubase vst32 and the only input ports showing up is channel 1-2. I would like to be able to program midi and listen to more than one synth at a time... tell me this is possible without having to break out my old mackie mixer. I was always under the impression that with the 001, i wouldnt need to use a mixer to network a couple synths into my sound card.
So long story short... how do I add the digi 001 input ports into Cubase VST/32?
thanks
pHil
Old 07-29-2002, 12:46 AM
vonbleak101 vonbleak101 is offline
Default Re: How do i configure the 001 audio ports for cubase?
Unfortunatly at this stage you cannot as the 001 does not have ASIO drivers yet fo PC, it is running on the WAVE driver which is limited to stereo in/out.
But dont dispare, i have heard that digi will be releasing an ASIO driver for PC, but not for at least 6 months or so. [img]images/icons/frown.gif[/img]
Audio Engineer/Musician/Producer
How to configure USB ports on MacBook Pro? patspahr9 Getting Started 8 12-12-2013 03:48 PM
Can't configure M-Audio Keystudio binaural42 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-31-2010 02:44 PM
How To configure 003, Protools and JK Audio Innkeeper 1x jbayfield 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-05-2010 08:30 PM
Digi001 configure with Logic Audio PC?!? joepanic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-10-2002 07:23 PM
SOLUTION! Digi001 midi ports with Cubase, DP or Logic! Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-25-2000 05:22 PM
