Old 10-24-2022, 08:36 PM
barden barden is offline
Default Firing A Key Command Brings Up EuControl Settings
If I try to fire a key command that I've programmed in EuControl Settings (or, at least, one that I think I've programmed) and, instead of doing what I hoped it would do, EuControl Settings opens up (i.e. the app opens), does that mean that something is wrong?
Is this a type of de-bugger error window that opens trying to prompt me to fix what I messed up?
Thanks!
~Barden
PT2202.7
EuCon 2202.4
macOS Monterey 12.4
MacBook Pro (16-inch, 2021) M1 Max
Old 10-25-2022, 09:01 AM
EddieJones's Avatar
Default Re: Firing A Key Command Brings Up EuControl Settings
You have either the Dock or S3 in Eye mode...look for the eye graphic, on the Dock its between the OK and Cancel.
Old 10-26-2022, 08:19 AM
Ah! I see! Perfect...thanks, as always, Eddie!
~Barden
PT2024.10
EuControl 2024.10
macOS Ventura 13.4.1
Mac Studio M1 Ultra 128GB RAM
HD Native / HD OMNI / Dock / S1
www.imdb.com/name/nm0002486
EuControl Assign Settings Impervious Artist Series 6 11-09-2021 12:16 AM
EuControl Settings changes itself walter rohrbach Avid Pro Mixing General Discussion 1 10-18-2019 09:13 AM
Eucontrol Settings Shortcut? Impervious Artist Series 5 10-27-2017 04:44 AM
EuControl settings micheallsmith Artist Series 4 03-01-2016 06:19 PM
eucontrol settings Phili Artist Series 0 02-28-2012 03:31 AM
