Mem Locs are an essential part of my mix workflow for track layouts (not to be confused with eucon surface layouts). I have EUCON softkeys that use my mem locs to recall those layouts as locations 1,2,3 (with time properties set to NONE). Now, when I make any kind time-based marker or new memory location, those three markers get pushed down the list and make my eucon softkey unusable since eucon is now pointing to a new marker that is unrelated. The only work around to this is to disable "sort by time" in the mem loc window. Is there another way to "lock" these non-time based locations so they don't move? I've tried replicating these layouts in eucon using groups. That works ok, but now I've lost control via keyboard and adding/deleting tracks from the group is a lot more work.
Have you ever found a solution for this? I'm also having trouble with the way memory locations are numbered differently in Eucontrol and Pro Tools.
I would love this functionality as well. I use several Memory Locations as track Show/Hide and Size in tandem with Window Configs recalled via Eucon. Being able to either directly access them via Eucon (ie not number based), or lock them in a position in the list (which I’m guessing is Pro Tools functionality, not Eucon), would be great.
If you use memory locations for things other than song/timeline markers, save these in higher numbers(I use 50, 51 and 52). That leaves 1 and up for song markers, but your locations won't get pushed down the list(at least not until you use up all the locations leading up to your layout numbers).
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
What you should know about memory locations !!! | clemens | Pro Tools 2019 | 4 | 12-12-2019 08:26 AM |
Memory Locations | Neurosis | Pro Tools 12 | 8 | 06-08-2016 04:32 AM |
Memory locations | RW1965 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-04-2006 05:27 AM |
Memory Locations | Fave | Pro Tools TDM Systems (Mac) | 2 | 04-05-2002 05:01 AM |
Memory Locations in PT5.1 | Brent Burge | Pro Tools TDM Systems (Mac) | 0 | 04-07-2001 04:02 PM |
