Old 06-14-2007, 08:21 AM
Bonjourmate Bonjourmate is offline
Default Issue with Amplitube Plug-ins Delay and Pro Tools
OS 10.3.9
In a song I'm working on we have one note with a delay effect from Amplitube bounced down to it's own track so that it's no longer using Amplitube at all. When the waveform of said note plays it warps all the other tracks. I know that it's just that one note because if I mute that channel... nothing, it plays through just fine.
Should I try re-recording the one note and re-applying the delay? I tried using Pro Tools stock Delay plug-ins, but they just seem to work like crap.
Old 06-14-2007, 09:51 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Issue with Amplitube Plug-ins Delay and Pro Tools
"warps all the other tracks"
I don't know what that means. Could you explain it?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-14-2007, 12:13 PM
I mean the sound of the entire Pro Tools file is going crazy right when the delay comes in... even though the effect is only on that one track (and since it's been bounced to disk and reimported to a new track it doesn't even have an effect going at all). Do you have an email I could bounce the whole piece (or at least the portion I'm having issues with) and send it to you so you can see for yourself.
I've gone through each tracks waveforms, volumes, etc and made sure (by checking them Solod one at a time) to figure out which one it is and I'm 110% certain what I said was causing the problem is, in fact, doing so.
AmpliTube plug ins fail with Pro Tools 9 monkeywrench Pro Tools 9 1 11-28-2010 11:54 AM
Delay Plug-In Issue firsty33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-06-2010 03:54 PM
Issue with PT 7.4 and Amplitube 2 LE drumrabbi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-11-2009 07:43 AM
Match Amplitube delay with session time rodrigo21 Tips & Tricks 1 06-20-2005 05:48 PM
Slightly OT: Delay settings in Amplitube BigCats 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-01-2003 07:53 AM
