Re: Lost S/PDIF Output/Insert (Digi001)
Assuming you are trying to access the RCA S/PDIF ports:
-Open the Setups>Playback Engine>Other Options window and choose "ADAT" from the Optical Format menu. -To get your I/O paths labeled correctly (and to add the additional S/PDIF output path), open the Setups>I/O Setup window and click “Default” for the Inputs, Outputs and Inserts tabs. Brent |
Ah splendid, Brent!
I'd already got as far as the "ADAT" as the Optical Format, but I'd also enabled the "S/PDIF Mirroring" option which caused the problem. All better now. [img]images/icons/cool.gif[/img] Thanks for the speedy response. Now to sit down for the afternoon and enjoy these 32 tracks. Have a great weekend. Phil
SoundPunk | Pro Tools Tips & Tricks |
Hi All,
Perhaps it's a simple preference I've overlooked, but... - Updated the PT 32T beta without any noticeable concerns. - Updated OS 9.1 -> 9.2.1 --> 9.2.2 - Deleted both Pro Tools 5.1 and 5.2 (or whatever they were called) preferences. Now it seems I can't access S/PDIF output or create a S/PDIF insert (via the I/O Setup window). Basically the S/PDIF ports are missing from the Digi001 icon in all but the 'inputs' view. I'll have to go back and re-test the 32Tbeta and 9.1, and then work out where it all went wrong, but if someone could point me towards a box or preference I may have overlooked, it'd be greatly appreciated. Cheers, Phil
Lexicon MX200 as a hardware insert (via S/PDIF) ? | KMcFadden07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-18-2011 11:24 AM |
No S/PDIF insert for Mbox 2 mixdowns??? | peppertree | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-30-2006 09:48 AM |
Digi001 Use s/dif as an insert | aztommot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-01-2004 03:00 PM |
Lost S/PDIF I/O with 6.1.1 and 6.1.2 upgrade | nedorama | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-09-2003 11:01 PM |
888 interface's s/pdif input doesn't like AMIII s/pdif output | jmark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-19-2001 01:03 PM |
