PCI to PCI-e with new Magma Chasis
Hello, I recently spent thousands to upgrade to HD PCI and then PCI E was released almost right after the upgrade! I cannot afford another full upgrade just to get the same equipment to run on a new PCI e only mac, I am wondering if anyone here is using the PCI to PCIe Expansion chassis available from Magma. It is only 1200 dollars and is much cheaper then upgrading HD2 PCI to PCIe (3500 dollars!)
Any insight would be appreciated! Thanks NK |
Re: PCI to PCI-e with new Magma Chasis
I'd be really wary of an expansion chassis that wasn't approved and tested by Digidesign. The approved and tested ones have enough trouble as it is. Even if the chassis you're talking about works now, a software change could easily break it.
Your best bet right now is to buy the Digidesign chassis, which gives you the option of a PCI or PCI-e host card. Lee Blaske |
Thanks for the reply,
You say that the approved chassis are having lots of problems? What problems are you aware of in regards to using the PCI HDaccell system with PCI to PCIe chassis? |
Magma Chasis PCI-7-RX and PT | Moncarz | Pro Tools TDM Systems (Mac) | 5 | 04-02-2011 03:15 PM |
Magma Expansion Chasis | budster | Pro Tools TDM Systems (Mac) | 6 | 03-18-2008 09:33 AM |
New Magma Chasis with Old PCI Cards??? | M2E | Pro Tools TDM Systems (Mac) | 6 | 03-27-2006 11:59 AM |
2 slot Magma Chasis with HD ? | TommyT | Pro Tools TDM Systems (Mac) | 2 | 04-06-2004 07:38 AM |
Magma 7-slot chasis and DAE | ESP | Pro Tools TDM Systems (Mac) | 4 | 10-18-1999 03:54 PM |
