Asr 10 keyboard
Does anybody use an asr 10 keyboard synched through midi to protools(master/slave)...? Is so, please help me synch it. Tried everything.
Re: Asr 10 keyboard
Hmmmm....might have to look into this. I actually use one for sequencing drum tracks via Alesis DM Pro, and even do some piano/synth/bass stuff on it from time to time, but have never actually used the midi output to feed Pro Tools. Thought about it, just to send it to an instrument track....shouldn't it be as simple as send ASR-10 midi OUTPUT to Digi Midi INPUT? Then selecting it in your setup preferences?
Which interface are you using? |
Re: Asr 10 keyboard
I use the 002r, i did the midi in/out from the asr to the 002 but when i hit the record on the 002 the asr wont play... I do full production with protools now but i have old stuff on the asr i want to transfer over.. I want to track 8 i/o's at one time but i just cant synch it. It's frustrating.. Thanks for the help!!!
Re: Asr 10 keyboard
One of my good buddies here in town said he'd teach me everything I needed to know about Pro Tools MIDI (he's VERY good) but NOT until I got all my midi devices talking to each other. So I haven't messed with it yet!!!!
However, if you have the ASR output expander, can't you assign each track to its own output, and patch the 8 ASR outs to the 8 002R ins and just dump them in analog? Other thing is, do you have your ASR set up to accept an external midi source? Used to sync mine to a stack of DA88's that way, using a smpte-midi converter. |
Re: Asr 10 keyboard
Yea i use the output expander on the asr, want to run them in to the 002 analog ins, but getting it to synch with protools is the problem.. So when i hit rec on pt the asr should start playing. I set the asr to receive external midi source but nothing happens. I'm wondering if i need to set pt to do something in preferences..?
Re: Asr 10 keyboard
I wonder if there's a way to do the opposite, and get PT to slave to the ASR-10? Might be more reliable.
Re: Asr 10 keyboard
Im gonna play around with that and see what happens. I'll keep u posted. Thanks again!
Re: Asr 10 keyboard
are your sync channels set up correctly between the two?? i have the ASR10 but have never sync'd it with PTLE. i did do it with my VS1680 at one point. sync channels setup was the biggie IIRC
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Re: Asr 10 keyboard
hmmm synch channels?? where do i setup those channels?
Re: Asr 10 keyboard
settings are under Peripherals=>Machine Control in PTLE. i'm not sure where the setting is on the ASR10.
RTAS Capslock Keyboard? Midi Keys triggered from computer keyboard. | aasteveo | Pro Tools 9 | 0 | 11-06-2011 06:17 AM |
Keyboard Shortcuts-Apple Thin Keyboard | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-15-2008 03:17 PM |
Keyboard shortcuts with foreign keyboard | torsig1967 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-08-2006 05:06 AM |
QWERTY keyboard as MIDI keyboard? | Herkimer | MIDI | 5 | 08-21-2006 12:07 PM |
keyboard shortcuts without an Apple keyboard? | doublestakked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-22-2006 05:04 AM |
