Old 10-18-2002, 02:23 AM
mihau mihau is offline
Default SIDE CHAIN EQ+COMPRESSOR COMPRESSING VOCALS
I 've read somewhere that is good to compress vocals on the specific frequencis...is this maybe the answer why am I getting so much high freq. when I compress my vocals recorded [img]images/icons/grin.gif[/img] with ati pro6 + U87...anybody??? Please let me know how can I use side chain EQ and Compressor???
Leave the kid alone
Old 10-18-2002, 02:46 PM
Zownd Zownd is offline
Default Re: SIDE CHAIN EQ+COMPRESSOR COMPRESSING VOCALS
I have only used this technique for de-essing and low end (pop) control. But I guess you could use this for any (problem) frequency.
you set up an aux send.
Then on your return you place an EQ.
With this EQ you emphasise your problem frequency by boosting the h*ll out of it (usually with a very narrow band). It also helps to filter away the "good" frequencies.
Now you route this return to any bus available.
(or on an analog desk to another pre-fader send...and close the fader off course)
Now on your vocal channel you place a compressor and activate the side chain to the specific bus you routed your EqAux channe to.
Now the compressor will only respond to those nasty frequencies you emphasized.
I hope this helps
Maybe you knew all this already, but others looking at this thread might find it to be helpfull.
you could also use this routing scheme to go to another send and use for instance a chorus before you go to your reverb. This will sometimes help to give a sound (vocal) more space in the mix.
Old 10-19-2002, 02:17 PM
Hit$quad Hit$quad is offline
Channel Strip makes it really easy to use.
Both of their compressor as well as the gate have a side chain activation. Compressor side chain works good for de-essing but if you want to experiment go right ahead. Some interesting things can come out.
[img]images/icons/cool.gif[/img] [img]images/icons/wink.gif[/img]
Don't confuse kindness for weakness
Creating a side chain compressor lownotesinc Tips & Tricks 10 02-09-2012 02:40 AM
Compressing R&B vocals (do you?) Scorpio253 Tips & Tricks 14 03-24-2009 09:25 PM
Compressor side-chain how to? porkipine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-15-2008 10:34 AM
compressing vocals twice? djc8902 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-19-2002 01:25 AM
Compressing Vocals ? Digital Musician 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-23-2002 07:07 AM
