ADAT Sync Error Messages
Hope someone can help with this.
I'm getting error messages now with my Digimax. I have it connected with the optical cable, and the sync set to Optical in the PT LE software, like it's been for 8 months now. I installed the POD software and ever since then, I'm getting the error message on opening a session: "A clock source could not be detected on the external sync input. Internal sync mode will be used until Pro Tools auto detects the presence of a valid external sync source." Once I click OK to this, I then get: "External clock source now valid." Once I click OK to this, I get the first again. And so on, and so on. I figured it was the POD software, so I uninstalled it and removed any traces of it from the HD and the registry, but this is still happening. Anyone have any ideas on this? I've changed optical cables, just to make sure. Nothing else on the PC has changed since this POD thing happened. Heath
Heath |
Re: ADAT Sync Error Messages
Well, I upgraded to the 5.11 version of PT LE and now instead of the error messages, I experience dropouts.
Anyone? Anyone?
Heath |
Trying a defrag of the audio drive, in case anyone's paying attention. Digi?
Heath |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Carcaridon:
I figured it was the POD software, so I uninstalled it and removed any traces of it from the HD and the registry, but this is still happening. Anyone have any ideas on this?<HR></BLOCKQUOTE> Although I'm not sure why this is happening, the Pod software could have mucked up Pro Tools in some way. Here are a few suggestions: Trash the following items from the system, restart and try PT LE again: -DAE prefs folder: Located in the C:/ Program files / Digidesign / DAE folder -PT prefs file: Located in the C:/ Windows/ Application Data/ Digidesign folder. -If that doesn't work, attempt a reinstall of PT LE (be sure to deauthorize DVerb before removing the PACE System Files). -If things are still rocky, reinstall the Wave Driver Brent |
here's an old post about this too...http: //duc.digidesign.com/cgi-bin/ubbcgi/ultimatebb.cgi?ubb=get_topic&f=32&t=000837
Incase anyone was having the same issues or following the thread, removing and reinstalling the driver fixed the problem. So it looks like Digi and Line 6 have driver issues with each other when the Digi breakout bix is being used as the MIDI in/out device.
Heath
Heath |
Sync I/O start up messages/codes??? | Armando | Pro Tools TDM Systems (Mac) | 4 | 02-05-2014 12:25 PM |
Many different error messages, Pro Tools aborting or unable to click messages off | riffmachine | Pro Tools M-Powered (Win) | 5 | 10-05-2010 04:15 AM |
Error Messages | Guitarboy Rocks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-12-2007 12:03 AM |
ADAT Clock Sync error on Macbook pro+002 URGENT!! | Rob Aubrey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 10-20-2006 12:01 PM |
002 DAE error messages | Brian Scott | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-12-2003 02:10 PM |
