Old 10-06-2004, 10:28 PM
Naagzh Naagzh is offline
Default Pre-roll record won\'t work...
In a session today I was recording vocal a new vocal track using a six-bar pre-roll. We did one pass, and then I switched to destructive record mode. When I clicked the play button (record was flashing in the transport window), the song started to play, but the record button stopped blinking, and so nothing could be recorded. The track was still record-enabled.
I saved and closed the session and PT, trashed preferences, and then re-opened the session. No luck.
I went back to normal (non-destructive) record mode, and still the same problem. Then, I disengaged the pre-roll and everything worked fine.
Why would this happen? Did I unknowingly alter a setting?
By the way:
Mac OS 10.3.2
PTLE 6.4
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 10-07-2004, 09:28 AM
max cooper max cooper is offline
Default Re: Pre-roll record won\'t work...
In the Operations menu, there's a Pre/Post-roll Playback setting...did you change it possibly? Also, when I record with a pre-roll, I don't really think about it consciously, but I think I press both record and play on the control surface, not just play. It won't record before your punch-point, and even if it does, there's undo.
664 The Neighbor of the Beast
Old 10-07-2004, 11:08 AM
To punch into record you have to be in either QuickPunch or TrackPunch mode so Pro Tools can use voice allocation correctly.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Pre-roll Record Jeffrey Talbot Pro Tools TDM Systems (Mac) 2 11-04-2010 12:36 PM
Record with pre-roll Stig Eliassen ICON & C|24 7 05-14-2010 06:44 PM
Pre-roll doesn't work but post-roll does :confused: pennard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-07-2009 12:26 AM
Pre-roll post-roll won't work, please help!! moon1pulse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-12-2006 08:51 PM
Pre-roll on record question porkipine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-29-2004 02:58 PM
