Old 12-10-2018, 02:30 AM
Kirby B. Kirby B. is offline
Default stuck at 256 buffer
Hi. In the newly installed 2018.10 on Win 10, I am stuck with 256 buffer w 002 rack. I know it is OLD, but could change buffer with 2018.4. 2018.10 works well on OS 10.13.6 - haven't tried Mojave yet.
Any ideas? Thanks.
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Old 12-10-2018, 02:46 AM
ibbod0 ibbod0 is offline
Default Re: stuck at 256 buffer
When you say you are stuck with 256 buffer, does that mean you can see other options for the buffer size but it won't change? or 256 is the only option shown?
If it's the latter, in my experience the problem is usually Windows or some software is using the interface and blocking Pro Tools from changing the buffer size. Maybe try disabling the 002r in windows sound settings (both in the playback devices and recording devices tab) and see if you get more options for the buffer.
Old 12-10-2018, 03:04 AM
Yes, 256 was the only option I had. I took your advice and uninstalled / reinstalled the 003 driver and that fixed it, so a big THANK YOU!
MacBook Pro Mojave
16GB DDR3
Old 12-10-2018, 09:03 AM
This is usually because Windows is trying to use your interface as its "Default Playback Device". Set that to use the on-board sound card to avoid this hardware conflict
h/w buffer stuck at 256 PT 11 harryk Pro Tools 11 11 07-04-2015 07:19 AM
Buffer stuck on 256 mattytoldhatty Pro Tools 11 7 02-19-2015 07:04 PM
002R ASIO stuck at 1024 buffer problem zolko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-28-2014 02:52 AM
Buffer size stuck ? bonzerboy Pro Tools 11 7 11-26-2013 08:43 PM
Mbox 3 Buffer Stuck At 256? ThaStartGate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-14-2012 10:14 AM
