Audio Midi setup utility problems
I am running PT 8.04 cs2 on a MAcpro 2.66 quad-core running snow leopard and the audio midi setup utility will not switch to my pro tools hardware for input or output. PT is working fine and outputs properly, but the utility won't switch so other apps like Jam only output to the Macpros speaker. If I boot from a difft drive running Leopard 10.5 the utility works fine. Would like to avoid a reinstall of everything........Any idea what might be causing the problem?/.....thanks
Re: Audio Midi setup utility problems
Which hardware are you using? If it's the 002/003 or HD keep in mind that the Core Audio driver is single client only meaning that, if you have Pro Tools open, it has exclusive use of the hardware. You must quit Pro Tools, then launch the Core Audio Manager and make sure it shows 'Connected'. You should then be able to switch your settings in AMS.
Sync I/O setup utility | sodium glow | Pro Tools TDM Systems (Win) | 3 | 09-16-2020 10:07 AM |
Midi Studio Setup problems & Plugin problems | J Nauti | MIDI | 0 | 03-02-2010 11:04 AM |
Audio/MIDI setup problems | Edgur | Pro Tools TDM Systems (Mac) | 4 | 09-03-2009 11:28 AM |
audio midi setup problems PLEASE HELP!!!! | Drunken Mixer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-23-2009 01:01 PM |
CoreAudio not in my Audio setup utility | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-12-2007 11:18 AM |
