Command|8 trouble with Win7 x64 & PTLE 8.0.3
I just bought a I7-860 with P7P55D-E Pro and 4 GB DDR3 to run PTLE 8.0.3 on Win7 x64 with a 002 Rack. The system seems very powerful and stable, not crashing once. But the Command|8 doesn't work properly on this system. The Command|8 transport won't work, and it only shows from strip 7 and further. The PT software faders don't respond to the Command|8, but the Command|8 faders do respond to the software. It also looses connection all the time. I've tried the new Command|8 8.0 drivers, but no go. It used to run smooth on another computer I had running XP. It is now set up in PT like this: Type: Command8 Recieve from: Command|8 Send to: Command|8 [Emulated] # Ch's 8 I would appreciate all help :) Sandra report below: ***** Start of Report ***** -------------------------------------------------------------------------------- <<< Computer Overview >>> -------------------------------------------------------------------------------- < Computer > Model: System manufacturer System Product Name Workgroup: WORKGROUP Host Name: XXX User: XXX < Processor > Model: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Speed: 3GHz Cores per Processor: 4 Unit(s) Threads per Core: 2 Unit(s) Type: Quad-Core Integrated Data Cache: 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache: 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache: 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing < Computer > Mainboard: Asus P7P55D-E PRO BIOS: AMI 0610 12/10/2009 Bus(es): ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/ SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes Total Memory: 4GB DIMM DDR3 < Chipset > Model: ASUS Clarksfield/Lynnfield DMI Front Side Bus Speed: 2x 2.41GHz (4.82GHz) < Chipset > Model: Intel Core Desktop (Lynnfield) UnCore Front Side Bus Speed: 2x 2.41GHz (4.82GHz) Total Memory: 4GB DIMM DDR3 Memory Bus Speed: 2x 670MHz (1.34GHz) < Memory Module(s) > Memory Module: Corsair CMX4GX3M2A1600C8 2GB DIMM DDR3 PC3- 12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module: Corsair CMX4GX3M2A1600C8 2GB DIMM DDR3 PC3- 12800U DDR3-1600 (9-9-9-24 5-34-10-5) < Video System > Video Adapter: Radeon X300/X550/X1050 Series (Microsoft Corporation - WDDM) (4 PS2.0, 2 VS2.0, 256MB, PCIe 1.00 x16) < Graphics Processor > < Storage Devices > WDC WD2000JS-00MHB0 (200GB, SA:186GB (C:) WDC WD5000AACS-00G8B0 (500.1GB:466GB (E:) (F:) TSSTcorpCD/DVDW TS-H552B (RAID:N/A (D:) < Logical Storage Devices > Hard Disk (C:): 186GB (NTFS) @ WDC WD2000JS-00MHB0 (200GB, SATA300, 3.5", 7200rpm, 8MB Cache) Reservert av systemet (E:): 100MB (NTFS) @ WDC WD5000AACS-00G8B0 (500.1GB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Data disk (F:): 466GB (NTFS) @ WDC WD5000AACS-00G8B0 (500.1GB, SATA300, 3.5", 5400rpm, NCQ, 16MB Cache) Optical Drive (D:): N/A @ TSSTcorpCD/DVDW TS-H552B (RAID, DVD+-RW, CD-RW) < Peripherals > LPC Hub Controller 1: ASUS P55/PM55/3400 LPC Interface Controller LPC Legacy Controller 1: T0 B3-53h Disk Controller: ASUS P55/PM55/3400 4 port SATA IDE Controller Disk Controller: ASUS P55/PM55/3400 2 port SATA IDE Controller Disk Controller: ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1: ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2: ASUS P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1: ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1: Intel 801xx/63xx SMBus < Printers and Faxes > Printer: Microsoft XPS Document Writer (600x600, Colour) Fax: Microsoft Shared Fax Driver (200x200) < Network Services > Network Adapter: Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet, 100Mbps) < Power Management > Mains (AC) Line Status: On-Line < Operating System > Windows System: Microsoft Windows 7 Ultimate Platform Compliance: x64 < Windows Experience Index > Current System: 3.7 -------------------------------------------------------------------------------- ***** End of Report ***** |
Re: Command|8 trouble with Win7 x64 & PTLE 8.0.3
I had a similar problem recently. I was using a Vista system. Same response from the command 8. It would not control PT but PT could control it.
The end result was a clean wipe of my system with loading Windows 7- 64. Then loaded PT 8 and allowed hardware drivers installed (including Command 8). Then loaded 8.0.3 but had to remove the drivers first from the Add/Remove programs in control panel. I then loaded 8.0.3 but did not connect the Command 8 or my 003r. I finally loaded the separate drivers for windows 7 (connected the Command 8 and 003r for that load). So far so good. I hope this helps. It was a bear to load/unload......... |
Ok Problem Solved.
Install WIN 7 64 Bit Disconnect ALL hardware ie; 002 rack,command 8,etc. Install PT 8 (I included Command 8 Drivers) Remove AUDIO Drivres (control panel add / remove) Install 8.0.3 Remove AUDIO Drivers of the 8.0.3 (control panel add / remove ) Install Audio Drivers 64 (download from digi site) Shutdown PC Power up 002 Rack Power up Command 8 Power up PC Good Luck!!! |
Thank you for your replies! I had forgotten this thread and stashed the Command|8 away, but now I'll try once again with your suggestions.
I had alot of trouble getting my C8 to work with windows 7. I followed this and it works great! Thanks!
i am running protools 8.0.4 with my command 8.....and i cant get the command 8 to control my protools....but my protools can command it.....ive tried all the above and still not working.....help plz
Input trouble with PT11 Win7 | Tom_Lane | General Discussion | 1 | 01-30-2014 01:54 AM |
Trouble with Eleven Rack on Win7 64bit.... | infiltrating | Eleven Rack | 10 | 09-13-2013 11:26 AM |
install ptle 8 in win7 so I an upgrade to 8.0. | rmet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-07-2011 07:08 AM |
Problem with Command|8 on PT8.1 HD1 Win7 64 | ynor | Pro Tools TDM Systems (Win) | 2 | 01-04-2011 09:55 PM |
Command 8 under Win7 32b with PTLE8.0.4cs2 | francois.fab | ProControl, Control|24, Command|8 | 2 | 12-05-2010 12:37 PM |
