Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 10-20-2021, 10:12 AM
satu55555 satu55555 is offline
Default No sound on templates
I'm new with Pro Tools First and have an issue with the templates. I have recorded with midi and this works fine, but would like to use the drums on the templates.
When I create a new project using a template, it gives me an error message saying "Some inputs or outputs may have become inactive because your audio hardware has changed. Some inputs are missing."
Then there is no sound to the ready drums. So when I press play, there is no sound and the sound levels don't show on Pro Tools First at all.
I use Pro Tools First on two computers so I don't know if this has anything to do with it.
Any ideas for how to solve this issue would be appreciated?
Old 10-20-2021, 01:01 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: No sound on templates
If you are using two different computers and they both have different audio interfaces, then the names of the inputs and outputs are most likely named something different and therefore, Pro Tools First can not find it.
You should simply be able to click on the input and output drop downs on each of your tracks and assign them to the inputs/outputs available on that system. Once you assign them, you should be able to hear audio on playback.
Will
System Details
Old 10-20-2021, 10:46 PM
Thank you Will! That worked.
Groove Templates NOT WORKING..?!- Where can you get the grove templates from ? Zee&Eli Tips & Tricks 16 12-22-2014 10:34 AM
Help Using Templates? LynxAudio Tips & Tricks 2 07-20-2010 03:08 PM
EQ Templates Raptor Virtual Instruments 3 06-12-2007 08:04 PM
Using Templates in PT LE yavuzj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-02-2005 09:09 AM
templates Andi R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-09-2004 01:11 AM
