Old 04-11-2003, 06:14 PM
ste72 ste72 is offline
Default How to connect unbalanced I/Os to C24 ?
who could suggest the best way to connect unbalanced connectors through DB25 connectors (ins & out) with control24 ? Is it a better choice to connect "GND" AND "-" , to leave "GND" not connected or to leave "-" not connected ?
What's the best way to reduce noise ?
regards
Ste
Old 04-23-2003, 04:45 PM
Default Re: How to connect unbalanced I/Os to C24 ?
Old 05-03-2003, 10:40 AM
Buzzz Buzzz is offline
You should connect the - pin and the ground pin of the C24 together. If you let the - pin float it will pick up noise, cause crosstalk, etc. This applies to both the inputs and outputs of the C24.
Old 05-05-2003, 03:51 AM
hi, i would connect + to "hot" and - to "cold" leaving gnd of balanced connection unconnected... what do you think ? connecting - and GND toogether it generates lots of noise.
regards
Ste
Unbalanced TS into TRS jack fenderrocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-02-2016 01:00 PM
Unbalanced/Balanced?????? kmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-05-2012 06:19 PM
Balanced and Unbalanced Fishman1 General Discussion 2 09-25-2005 12:27 PM
unbalanced monitoring pk_hat ProControl, Control|24, Command|8 1 06-27-2003 09:07 AM
Can I go Unbalanced into C24? Hardnox ICON & C|24 3 07-21-2001 01:12 AM
