Old 07-20-2013, 05:13 PM
colourednoise colourednoise is offline
Default "pro tools hardware is either not installed or used by another program"
Just started receiving this on PT start up:
My hardware is a 002 Digidesign control surface, however even without of the 002 switched on & unplugged; I still get the same results.
Any ideas?
Mac: Mavericks, rMBP 15" Late 2013, i7 2.6GHz, 16GB DDR3 mem. PC: W7 Ultimate 64 bit, Intel Core i7-2700K 4.80GHz Processor Count: 8, ASUSTeK P8H77-V, 16GB Vengeance DDR3 mem, x2 XFX Radeon HD 7870 2GB DDR5, x1 Samsung SSD 830 Pro 256GB - x3 Samsung 7,200 1TB HDD's - T.C. Electronic Triple C, Presonus Studio Channel, Behringer T1953 mod, Neumann TLM 103 MT, Beyerdynamic MC840, Tascam M-164UF, Digi 002 C Surface, Asus Essence ST - PT 10, Waves 9, Serato Pitch 'n Time, Speakerphone, FR D2 & D3
Old 07-20-2013, 05:27 PM
Default Re: "pro tools hardware is either not installed or used by another program"
Did you install the 002 driver? Its a separate install. Then, hold the N key while opening Pro Tools so you can go directly to the Audio Engine select page and select either the 002 or the core audio(onboard) for Macs, or if you have Windows, try downloading ASIO4ALL, which SHOULD allow you to use the onboard audio, but use ASIO4ALL as a last resort as it CAN cause problems. On my rig, ASIO4ALL caused the 003 to not work(but as soon as I uninstalled ASIO4ALL, everything worked dandy(was trying to use another interface).
Old 07-20-2013, 05:38 PM
Yeah I have the latest digi 002 control surface driver installed. I have already tried that, it then defaults to the ASIO4ALL option which gives out the same message, also it always changes back to the original selection each time.
I will try to figure out how to uninstall my copy of ASIO4ALL.
Old 07-20-2013, 05:43 PM
My bad, I must have forgotten to re-install ASIO4ALL after I last formatted. Turns out it's another PCI soundcard that was displaying. Instead of clicking 'Ok' I clicked 'Cancel' and it loaded straight up?!!
I am now however been confronted to re-register my copy of Pro Tools.. something not quite right going on, but never the less I'm back in for now.
Thank you for your input.
"Pro Tools hardware is either not installed or used by another program." Crocklip Pro Tools 10 6 12-18-2014 01:21 PM
"pro tools hardware is not installed or is in use by another program error" beatingunicely Pro Tools 11 0 01-17-2014 09:14 AM
Protools 10:"ProTools Hardware is either not installed or in use by another program" danielme Windows 0 04-19-2012 10:05 PM
HELP: "Pro Tools hardware is either not installed or used by another program" defmuse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-16-2010 12:59 AM
Digi 003 "Pro tools hardware is not installed or is being used by another program" tryn2chanjdgame 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-20-2009 03:37 PM
