Re: How to map a send to a plugin instead of just a fader?
Hmmm, I've been using PT for 20 years and never needed or wanted this. Having said that, maybe there are options the OP is missing, such as:
1-add another screen so some plugins can remain open on their own screen(hit the red "target" in the upper corner of a plugin to keep it open). 2-instead of clicking on a send to open it, keep the row of sends showing the small fader(Ctrl-click on the little chiclet next to any send box).
Thanks for all the help, sadly figured it might be impossible.
It makes sense now. It just looked so fluid but I did think of that too: If multiple plugins are on a send then what? But also I guess the point of the workflow is simplicity and quickness: So either those other plugins would: Not be in use, not show anyway, or would be at a fixed setting while controlling the one plugin that you want to use. In any case thanks for all the help, If I find any way to get close or any types of workflow improvements in this style ill respond here. Thanks Everyone. Also, I saw someone mention the the gif is hard to see, It is. Here are the timestamps on YouTube: 1:41 , 1:50. Again. It looks so smooth to not have to scroll to the aux or track that you are send to, but I can do without if need be. |
Okay. Thank you for this. I didn't think of this. |
Thanks for this as well. Will do. |
It's just how plugins work in PT.
Either you have the plugin inserted on one track - or you have it inserted on a aux track; most often you do that to be able to use sends to be able to have several tracks share the same plugin. Typically a reverb on a aux that more than one track can send to. Also there is Audiosuite. Pull up a plugin from the Audiosuite menu and you get a floating plugin window, select a region on a track, and process that region with the plugin. IzzyTay88; I see you edited the post with the gif to ave more info and links to video - I think it would have been better if you created a new post with the new info. More tidy.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
#16
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
#17
Thank you so much, now If only I could find a way to make a script. |
Linking Send Fader Window to Plugin Window. | IzzyTay88 | Getting Started | 0 | 06-19-2022 11:32 AM |
Volume fader vs post send fader - same scale? | Vitopower | Pro Tools 2019 | 5 | 07-09-2020 06:11 PM |
Using fader for send | Jazzbass56 | Avid S1, S3, Dock and Control App | 8 | 05-13-2020 07:33 PM |
send fader | erocker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-30-2009 05:35 PM |
send fader loss!! | K.I. | ICON & C|24 | 5 | 01-14-2007 05:40 PM |
