Plugin menu favorites
I never used the plugin menu favorites feature much, but I thought I'd clean it up and start using it more. Good when using Artist Mix.
I have plugins sorted by both category and manufacturer, and I like it that way. Now, I can add a favorite by holding command and clicking it. It shows up inn the plugin menu above the categories. If I command-click it again it goes away. Here's what I can't seem to fix, it's probably something simple; A couple of plugins sits in the menu, one level up; under 'search…' and above 'Plugin'. I've tried every modifier key, searched, and tried a tip I found about holding opt-cmnd and clicking 'No insert', which is supposed to clear all favorites. It clears the favorites I mentioned first, but not the ones under 'Search…'. Any thoughts?
Re: Plugin menu favorites
I find that the two favorites I can't get rid of (under 'search' and above 'plugins') shows up on the artist mix controller. But if I create a new favorite (cmnd-click) it shows up above categories and manufacturers - but are not available on the artist mix.
I have a sense that this might be eucon-related. I've tried setting favorites with the artist mix powered off, it makes no difference.
Nope. Just my own stupid fault.
The two 'favorites' is simply the prefs setting 'default EQ and dynamics'. Set them to none and they're gone. Also I am now able to see my newly created favorites on the controller. Move on. Nothing to see here.
SOLVED - Plugin Favorites Disappearing? - A Manual Update & Warning Dialog Box!!?? | tmuzik | Pro Tools | 0 | 07-09-2021 12:13 PM |
Plugin Favorites Bug | Jperkins | Pro Tools 12 | 2 | 06-27-2017 06:02 AM |
pro tools plugin menu, and options menu blank | lucidlife | Pro Tools 10 | 4 | 12-07-2014 12:16 AM |
Plugin Alliance Favorites...? | WKG | AAX Plug-ins | 4 | 12-31-2013 02:29 PM |
plugin menu | clausiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-28-2003 11:41 AM |
