Relinking files required after session folder reinstall?
Had an HDD crash, so had to reinstall my Audio drive from backups. All good, lost nothing (supposedly).
So then opened one of my sessions from the new drive, and had to relink a bunch of files. That worked fine, but then I get error 9060/9031 and it wont play back. So I set up a new sesssion and import session data and it is fine. I am now doing this for all 4 albums we are working on....taking hours. This looks like a major bug. All the files are there, but protools doesnt like the session once you have relinked. Also, how does it lose the links when you move the session folders from one place to another? Nothing else changed, the folder sizes were the same from source to destination (I checked, as am paranoid). WHAT A TOTAL WASTE OF MY TIME!!!! I am running 9.05 HD (TDM), on MacOSX 10.6.8, on a 3ghz quad macpro 1.1, with 6gb of ram. |
Re: Relinking files required after session folder reinstall?
Pro Tools uses absolute file paths for file linking. If you have a file at /My Audio Drive/My Session/Audio Files and then you restored your data to /New Audio Drive/My Session/Audio Files then Pro Tools will not be able to find the files. Auto-relinking isn't much better, as it starts at the root of the drive and goes through all of the directories alphabetically until it finds what it is looking for. It does not start searching in any directories that are in the same directory as the session document.
So, whats the best way to manage the files if you have to move session folders? do you use the copy function in the file menu of Protools?
I move the files, and when I reopen the session and it asks to relink, I choose the manual option and select the moved directory.
Will try that, thanks.
importing pro tools for mac session files into windows help required please | Minkels | Windows | 5 | 08-20-2011 07:21 AM |
Relinking Fade Files when Importing Session Data?! | Simmer | Pro Tools TDM Systems (Mac) | 2 | 12-11-2010 04:45 PM |
Relinking session files | go141 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-02-2009 06:46 AM |
Session Did Not Save - Audio Files Not in Folder | Ricky Cobble | Pro Tools TDM Systems (Mac) | 2 | 02-17-2009 02:38 PM |
Session can't find files in same folder! | duanebonney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-11-2004 03:46 PM |
