Old 04-18-2010, 07:20 PM
nz nz is offline
Default Plug parameters with Euphonix MC Mix
I know there is a very simple answer for this that I am missing. Any help would be appreciated.
I am using a two Euphonix MC Mix controllers and am wanting to control various plug in parameters with the top row of pots on these units.
When I pull up a plug (in this case, a Waves plug) I can see on the plug itself that a few of the parameters are highlighted in blue or red. When I go to control these with the MC Mix pots the parameters that are available are only the ones on the first unit. None of the other parameters are available on the other 8 knobs on the second unit.
How can I set it up that I can use my second MC Mix unit to control the rest of the plug parameters that are now unavailable?
Thanks so much!
nz
Old 04-19-2010, 10:10 AM
nz nz is offline
Default Re: Plug parameters with Euphonix MC Mix
bump
nz
any way of extracting plug-in parameters Craig F General Discussion 6 12-04-2011 04:58 PM
Groups for plug-in parameters in PT-LE? David Topple 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-18-2011 09:50 AM
Plug in parameters and the 002 funkcore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-02-2006 10:21 PM
Automating plug-in parameters? Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-27-2005 09:39 AM
Re: Plug-in Parameters filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-19-2005 09:13 PM
