Changing the MIDI tempo track in Pro Tools LE
Is it possible to change the MIDI tempo track at any point in a session of Pro Tools LE? I'm using multi-sample plugins and need to gradually slow down the tempo towards the end of a song. I know MIDI is not one of Pro Tools strong points, but can it be done like in Cubase SX? I'm using an M-BOX2 with Pro Tools LE (7.1). Any help or advice will be greatly appreciated. Thanks.
Re: Changing the MIDI tempo track in Pro Tools LE
Yes, you can. Use the tempo editor or change it in the MIDI properties. Look through your guide pdf's, PTLE version 7.0-7.3 have quite a bit of MIDI functionability.
"Sometimes having limits keeps you sane"- Albee1952 |
NVM. Sometimes I run before I can walk. Thanks for the quick reply.
...and so your notes stay with the Grid, make sure Tick-Based Timing is checked.
filosofem
Aaron Mulqueen - 001 HD Native |
Need to Change tempo but without changing existing midi data tempo? | Einsteinwannabe | Pro Tools M-Powered (Mac) | 2 | 09-18-2010 06:58 AM |
Midi Click Track Changing Tempo? Tell it aint so. | heybluez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-05-2007 06:51 AM |
Changing tempo w/out changing midi performance??? | toddm7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-12-2005 10:35 AM |
changing tempo without changing midi | wizdoom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-20-2004 05:40 AM |
Changing tempo on an audio track for Pro Tools LE | GooseGossage | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-18-2004 08:44 PM |
