Old 04-08-2015, 03:52 PM
Herkimer Herkimer is offline
Default Mbox 2 Micro compatible with PT11?
According to this Avid compatibility page, the Mbox 2 Micro is supported for PT11.
I've installed PT 11.3.1 Win84152 and Mbox Drivers v90625.
My Mbox 2 Micro works perfectly with PT10. I can go to the "Playback Engine" and the Mbox 2 Micro is listed with multiple H/W buffer sizes up to 1024. Playback runs through the Mbox 2 Micro as expected, ie, I can hear it with headphones in the Mbox 2 Micro port.
Open PT11... It's not an option in the Playback Engine. I only have Mbox 2 at 256 H/W buffer. If I proceed with that and open a session, it doesn't playback through the Mbox 2 Micro.
Any suggestions? Need a Sandra report?
____________________________________
Home Build:
Core i7 920/Gigabyte EX58-UD3R/6Mb Ram
Mbox2/MboxMicro
ProTools 8.0
Old 04-08-2015, 04:07 PM
sw rec sw rec is online now
Default Re: Mbox 2 Micro compatible with PT11?
Is Windows designating the Micro as a playback device? It shouldn't...
Old 04-08-2015, 04:28 PM
Would that lead to differentiation between PT10 and PT11?
-nope. not that. I disabled it as a playback device with no luck.
Home Build:
Mbox2/MboxMicro
ProTools 8.0
Old 04-08-2015, 04:57 PM
Sandra report:
SiSoftware Sandra
ID
Host Name : MKC_laptop
Workgroup : WORKGROUP
Computer
Model : HP ENVY m4 Notebook PC 103C_5335KV G=N L=CON B=HP S=ENV
Serial Number : 6CE23*****
Chassis : HP Notebook
Mainboard : HP 18EE
Serial Number : PCWSRA1*******
BIOS : Insyde F.12 10/26/2012
Intel vPro : 8.01.00.1248
Total Memory : 7.9GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz (4C 8T 2.2GHz, 2.2GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC PGA988
Chipset
Memory Controller : HP Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : Kingston HP536727-H41-ELD 4GB DDR3 SO-DIMM PC3-12800S DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : LGD Generic PnP Monitor (1600x1200, 13.9")
Video Adapter : Intel(R) HD Graphics 4000 (16CU 16SP SM5.0 350MHz/1.15GHz, 32MB DDR3 1.6GHz 128-bit, Integrated Graphics)
Graphics Processor
OpenCL GP Processor : Intel(R) HD Graphics 4000 (16SP 16C 1.15GHz, 1.4GB DDR3 1.6GHz 128-bit, Integrated Graphics)
Compute Shader Processor : Intel(R) HD Graphics 4000 (16SP 16C 350MHz/1.15GHz, 64MB DDR3 1.6GHz 128-bit, Integrated Graphics)
Storage Devices
WDC WD10JPVT-60A1YT0 (1TB, SATA300, 2.5", 5400rpm, 8MB Cache) : 932GB (C:) (D:)
hp DVDRAM GU60N (SATA150, DVD+-RW, CD-RW) : N/A (E:)
Logical Storage Devices
Hard Disk (C:) : 906GB (NTFS) @ WDC WD10JPVT-60A1YT0 (1TB, SATA300, 2.5", 5400rpm, 8MB Cache)
RECOVERY (D:) : 25GB (NTFS) @ WDC WD10JPVT-60A1YT0 (1TB, SATA300, 2.5", 5400rpm, 8MB Cache)
WINRE : 400MB (NTFS)
Hard Disk : 451MB (NTFS)
Optical Drive (E:) : N/A @ hp DVDRAM GU60N (SATA150, DVD+-RW, CD-RW)
Peripherals
LPC Hub Controller 1 : HP Panther Point LPC Controller
LPC Legacy Controller 1 : Winbond W83687THF
Audio Device : HP Panther Point High Definition Audio Controller
Audio Codec : Integrated Device Tech 76E0
Disk Controller : HP Mobile SATA RAID Controller
USB Controller 1 : HP Panther Point USB xHCI Host Controller
USB Controller 2 : HP Panther Point USB Enhanced Host Controller #2
USB Controller 3 : HP Panther Point USB Enhanced Host Controller #1
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer v4 (600x600, Colour)
Printer : HP ePrint (600x600, Parallel, Colour)
Printer : doPDF 7 Printer Driver (2400x2400, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet)
Wireless Adapter : Ralink RT5390R 802.11bgn Wi-Fi Adapter (802.11n (HT), AES-CCMP, 72Mbps)
Power Management
Battery No 1 : PegaTron HS1 61.99Wh/4.86Ah
Operating System
Windows System : Microsoft Windows 8 Home 6.02.9200
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Home Build:
Mbox2/MboxMicro
ProTools 8.0
Is the Focusrite Saffire Pro 24 compatible with PT11 CG Kid Third Party Interfaces 4 10-10-2014 02:18 PM
Orchestral VST's compatible w/ PT11 musiclee AAX Plug-ins 15 04-06-2014 06:59 AM
Is Mobile Pre USB compatible with PT11? bluebe11 Pro Tools 11 2 10-16-2013 01:09 AM
PT11 compatible UA Apollo interface? djkikis macOS 4 07-05-2013 07:44 PM
Will HDX not compatible with PT11? or not the best for Pt11? Rockman413 Pro Tools TDM Systems (Mac) 5 10-26-2011 10:00 PM
