Old 05-26-2023, 05:33 PM
basehead617 basehead617 is offline
Default Assignable knob -> Jog wheel not working
PT 2023.3 / S6+WSControl 2022.12.1.34
New session, make an audio track..
Hover over pan or fader in mix window for assignable knob access, press knob to lock - press back button (purple) to send to jog wheel.
Jog wheel does nothing to the parameter despite lighting up properly with the LEDs around it..
Am I missing something or is this busted?
Old 05-26-2023, 06:00 PM
Default Re: Assignable knob -> Jog wheel not working
Scratch that.. the jog wheel itself is dead… Was working yesterday
Tried forcing firmware but no help there.. will contact support.. any recent jog wheel component issues Eddie? (new system)
Diagnostics for automation module when you do Encoder shows Counter Rotate/Raw 0/0000 and nothing happens when using the wheel..
Old 05-30-2023, 03:25 PM
EddieJones's Avatar
I literally have never heard of it stop working. It uses a high-quality bourns encoder that we have used for decades. Did you power cycle the module?
Old 05-30-2023, 06:50 PM
It’s been power cycled, i’ve re-flashed the firmware, etc..
According to the diagnostics (if it’s Encoder) it’s simply not sending any values. Video on my case shows this. when in Jog or Shuttle the ffwd and rewind LEDs both light up as do the buttons in the UI, but the knob does nothing..
Could it have an unseated wire? It worked for one day.
Assignable Knob with Dock Jog Wheel in Cubase daveotero Avid S1, S3, Dock and Control App 12 05-02-2022 09:45 AM
S6L 5.6.0 -- Assignable Knob AlainJRoy VENUE Live Sound Systems 1 02-13-2018 01:42 PM
5-MC Assignable Knob Mike Hybrid System 5 1 08-23-2017 06:38 PM
wheel command: Assignable knob ?? crustn Artist Series 9 06-27-2015 09:14 PM
Only one assignable knob? Xill Artist Series 1 11-01-2011 11:30 AM
