The ASIO Driver Solution!!!! Reason, RealOne,
If you want to use the ASIO drivers, but also want to run apps like Reason or RealOne, and you lack an ASIO soundcard, Here is a solution:
You will need the ((.5 mm stereo to 1/4" mono(2x) patch cables)). Connect the soundard OUT to 001 INPUTS 3 & 4. Now if you hit the Monitor Mode button, your back in business. Sound is controlled by monitor knob. "..so that's what that button does." Dova Blue
TDM Ambition, LE Budget... |
Re: The ASIO Driver Solution!!!! Reason, RealOne,
I downloaded Cubase SX demo (which uses ASIO) and the Reason 2 demo (which doesn't use ASIO) and was able to listen to the audio output of both softwares.
Just not at the same time. db
PT9 - 003 rack -ASIO DRIVER error with Cubase 4.5 - any solution? | Kev79 | Pro Tools 9 | 4 | 11-15-2010 01:24 AM |
cannot select ASIO digidesign driver in reason adapted 3.0 | sidoZe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-09-2009 04:33 PM |
ASIO Driver with Reason, Ableton, etc. | moonpuppy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-21-2005 05:07 PM |
ASIO driver for REASON doesn't work! | catalyst718 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-12-2003 02:57 PM |
ASIO driver for REASON doesn't work! | catalyst718 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-12-2003 02:56 PM |
