Inputs changed
Hi there all. This is my first post in the mac forum. I recently opened a session that was recorded using the 828's on my digi 002. After opening the session all of my inputs inside protools changed to the 828 interface. When I try to change them back it only gives me the option of the 828's.
So I made a new session and my inputs and outputs are still assigned to the 828's. This would be a minor problem if ProTools would still playback, but it will not because it does not recognize the hardware. How do I solve this problem. Do I need to reinstall PT. Sorry about the long winded post. Thank you in advance. Kris.
Sign up for all things....AWESOME! Kris May the music move you |
Re: Inputs changed
Just go to you I/o setups and hit the Default Button or import any saved I/O setups you might have.
Enjoy
G5 Quad 2.5 Digi 002 G5 D 2.0 HD 3 Accel Control 24 - (2)192's |
Re: Inputs changed
Thank you very much. I overlooked that.
kris
Format cannot be changed - setting up inputs | trock | Pro Tools 9 | 0 | 11-05-2010 05:14 PM |
Using Eleven Rack inputs like POD X3 inputs | dayslypper | Eleven Rack | 1 | 10-09-2010 09:15 PM |
Analog inputs 5-8 not seen as inputs on tracks | sitarartist | Pro Tools M-Powered (Mac) | 4 | 09-16-2010 08:24 AM |
How do I utilize the Line inputs when all my XLR inputs are being used? | 007audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2009 08:21 PM |
Ive Changed | Chompers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 05-22-2002 08:18 AM |
