Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 08-26-2021, 03:33 PM
rmccam rmccam is offline
Default Playing Mac Audio Through MTRX Studio
Hi Everyone,
I'm trying to figure out the best way to play sound from my Mac Pro (Spotify, Vimeo, etc.), through my MTRX Studio, while Pro Tools is open.
I've read some threads but I don't know what's current. Is the Dante Virtual Soundcard still the best way to go? It's sort of a kicker to have to pay $50 just to listen to your computer's sound. Haha!
Any suggestions would be welcome.
Thanks!
Ryan
Ryan McCambridge
Producer • Sound Designer • Mixer
Old 08-26-2021, 04:45 PM
Ben Jenssen's Avatar
Default Re: Playing Mac Audio Through MTRX Studio
I can highly recommend Soundsource.
I've used it with several macs and versions of mac OS, and it's always been really stable and reliable. I can't remember a single hickup. It's a tiny item in your menu, but open it up and it can do lots of useful stuff; per-app-settings, use AU plugins on individual apps, extensive routing options and lets me use F10-F12 keys for overall sound level/mute and more. If you don't need those things, it stays out of your way. Never a conflict with PT.
It's $49 but there's a demo, and I think it's well worth the money. If it works with MTRX, that is. I see no reason why it shouldn't. Except if MTRX isn't using coreaudio…
Old 08-27-2021, 03:56 AM
uptheoctave uptheoctave is online now
99% sure Soundsource won't work with HDX for the reason you describe- HDX would need to be available to Core Audio for Soundsource to work.
It won't be when pro Tools is running.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 08-27-2021, 04:18 AM
JFreak JFreak is online now
Take the optical out of Mac and wire it into optical input of your interface.
Old 08-27-2021, 04:51 AM
Current Mac Pro doesn't have optical.
If he has 2012 or earlier then that is ok.
Or some Thunderbolt docks have it.
My (massively over engineered solution) is to us an audio interface with analogue out and then a 2 channel analogue to Dante adapter to put the signal on the Dante network.
It means clocking issues aren't a problem- the native interface can change sample rate without the MTRX having to ever change its sample rate.
Cheaper than the MTRX's sample rate conversion capable AES card.
James Richmond
Affiliate Links:
Old 08-27-2021, 05:05 AM
Another option is to use a monitor controller that supports multiple simultaneous sources.
The SPL MTC2381 is one.
I believe the Crane Song Avocet is another.
The Grace M905 is not.
James Richmond
Affiliate Links:
Old 08-27-2021, 05:23 AM
Sardi Sardi is offline
EDIT: OTHER POSTS WERE ADDED BEFORE I FINISHED TYPING MY REPLY. DINNER WAS CALLING.
What MacPro do you have?
If it’s an older Cheesegrater, you could go optical out to optical in on the MTRX. Run all your system sounds off the internal audio card and have them appear in PT with a track set to input monitoring.
This of course is also assuming you have an ADAT port on the MTRX not being utilised.
Old 08-27-2021, 06:24 AM
its2loud its2loud is offline
Are you using any of the line inputs into MTRX?
If not, you have 8 to choose from that you can hardwire your macs output with one of these in place.
https://www.sweetwater.com/store/det...evel-converter
Ultimately you’re gonna have to spend some money for either a hardwired solution or software solution.
Personally, I’d opt for the DVS/Dante VIA combo. But at least with the hardwired version you don’t have to worry about DVS running all the time on your Mac and needing to route things in Dante Controller.
Old 08-27-2021, 06:58 AM
creativecontrol's Avatar
Even if you had a legacy Mac (or TB Dock on a newer Mac), the MTRX Studio doesn't do Optical SPDIF - which is what you would need, ADAT only.
Even though DVS gets a bad wrap - it can still work just fine for system audio - otherwise pivot to James' external audio interface recommendation.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-27-2021, 07:02 AM
Marsdy Marsdy is offline
Originally Posted by rmccam View Post
Hi Everyone,
Thanks!
Ryan
Once set up, DVS works fine, except if you need to change sample rates in Pro Tools. This obviously switches sample rates on the MTRX Studio but unfortunately DVS doesn't keep up. It doesn’t automatically switch rates and you’ll lose output from the Mac. It gets annoying very quickly!
If you don’t regularly switch sample rates in Pro Tools, DVS works fine, at leat it did for me.
Dave Marsden
UK
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
MTRX Studio Audio Midi Setup Goombot Pro Tools 2020 6 02-25-2021 08:35 AM
MTRX Studio to Mac Core Audio? Cheesehead Pro Tools | MTRX & MTRX Studio 10 08-31-2020 04:59 PM
MTRX not playing back 96k audio from Pro Tools djkrayz Pro Tools | MTRX & MTRX Studio 4 08-25-2020 09:46 AM
