Old 09-26-2003, 02:34 PM
Vaphoron Vaphoron is offline
Default G5 compatibility details are here...
http://www.digidesign.com/news/details.cfm?story_id=243
- Jason
Old 09-26-2003, 07:29 PM
Sound-Influence Sound-Influence is offline
Default What\'s the 2.0 difference...
As one who has a dual 2.0 G5 on order, I wonder what the snag is with it's compatibility. Will PT simply not work at all in a 2.0 yet, or is it just not yet “supported”?
Any insight? Thanks,
Aubrey
PT 7.4cs2 | OS 10.4.9 | Dual 2.0 G5 7g Ram | HD3 Accel | 4 FW800 Drives
Old 09-26-2003, 08:34 PM
MAXIMUSIC MAXIMUSIC is offline
Default Re: What\'s the 2.0 difference...
Same here.....
is the dual 2.0 not supported or have not been tested yet?
Life is good !!
Marcello Azevedo
Old 09-26-2003, 10:44 PM
AvidCS's Avatar
AvidCS AvidCS is offline
If you check the Hot News link you will see that the G5 2 Ghz Mac is scheduled for approval in the phase 2 release expected sometime in the middle of November.
It is currently in test and will not work without a patch release of the PT application.
DigiCS
Old 09-27-2003, 07:08 AM
Tim R. Tim R. is offline
Default Re: G5 compatibility details are here...
I don't quite understand the Mix/24 part
quote:
"Supported Configuration Summary
* Computers: Power Mac G5, 1.6 GHz, 1.8 GHz, and 2.0GHz models
* Pro Tools Systems: Pro Tools|24 MIX
* Mac OS: TBD dependent on Apple’s release timeframe for Mac OS X 10.3
* Limitations: MIX I/O, d24 Core, and DSP Farm PCI cards are physically incompatible with PowerMac G5s"
Isn't this a contradiction (1st and last statement)? Is there a planned workaround?
Tim
Tim Reisig
System 1: Pro Tools Ultimate 2021.10, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 21.10, Rosetta 800 w/XHD card
Mac OS 10.15.7, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2020.6 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Old 09-27-2003, 08:22 AM
RobMacki RobMacki is offline
Chassis: Magma 64-bit, 33 MHz chassis (additional chassis support expected in later phase)
Does this mean the 32 bit 4 slot?
"Phases" meaning the 3 phases mentioned or later than that?
Old 09-27-2003, 11:56 AM
Danny Caccavo Danny Caccavo is offline
Tim
The Pro Tools|24MIX Core and MIX Farm cards are expected to be qualified in "Phase 3" for the G5. The MIX I/O, d24 Core (used with some Pro Tools|24MIX systems) and the DSP Farms (used with some Pro Tools|24MIX) are of the older 5 volt variety, and won't even fit into the G5. This information is also in the Hot News statement.
Danny Caccavo
Product Manager
Digidesign
Old 09-27-2003, 12:03 PM
If you're referring to the 4 slot CardBus chassis, that chassis is only qualified with PowerBook G4's.
Old 09-27-2003, 12:21 PM
Yes.
I use it with my G4ti and G4 400 (pci graphics) via:
"MAGMA's patented PCI Expansion Technology is incorporated into a short 'universal' PCI card, extending the PCI Bus outside of your host computer. Our 1 to 1.5 meter flexible cable provides a high-speed communication link from your computer or server to our PCI Expansion System."
So I use both.
Are you saying there will be no confirmed compatibility with G5 in this config?
Old 09-27-2003, 01:29 PM
We do not test the 4 slot expansion chassis with anything but the Powerbooks. This doesn't mean it *won't* work, but that configuration is not qualified by us.
PT9 Eucon..... details?? propower Artist Series 14 01-11-2011 08:19 PM
File Details ickymix VENUE Live Sound Systems 1 12-31-2010 08:04 PM
Registration Details Help Digiliz General Discussion 0 02-22-2007 07:58 AM
Details on the 001-002 exchange??? crs117 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-02-2004 04:40 PM
NI HTDM new details peteri Pro Tools TDM Systems (Mac) 3 11-15-2001 12:28 AM
