Old 12-19-2002, 11:33 AM
3rdstory 3rdstory is offline
Default How to run headphones through Mackie to avoid latency
I know this topic has been brought up more than once. I've read posts on how to do this, but I can't seem to find any of them when I search.
As recommended by many, I want run my headphones through my Mackie 1202VLZpro so that I don't experience any latency during multi-tracking.
For those of you that already do this - please tell me how to route my gear and what settings to make to acheive this ... or direct me to a post that already explains the procedure.
Question: When the low latency setting is checked in PTLE, plug-ins are disabled. Will I be able to use plug-ins - and hear them - if I run my headphones through the Mackie?
Thanks.
Old 12-19-2002, 11:49 AM
Anthemmusic Anthemmusic is offline
Default Re: How to run headphones through Mackie to avoid latency
Hello!
I use the 1604 vlz Mackie. To monitor with the Mackie, I simply run the out put of Digi 001 thru two channels panned L&R, and any synths I may be using thru the other channels. My mic is going into my preamp directly into Digi. I simply record with the buffer at 128(without using low lantency monitor) and I really don't hear any latency. If it's there it's not affecting anything.
I use the Control Room out of the Mackie into my power amp into my speakers. I use the main outs into a headphone mixer.
Hope this helps! [img]images/icons/smile.gif[/img]
Christian Music Productions For the New Millennium
To avoid latency in monitoring in record... solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 03-12-2009 05:35 PM
How do you avoid latency when converting Ext synth to Audio? Barron Pro Tools TDM Systems (Mac) 2 09-18-2007 12:41 PM
How to avoid latency recording with GR2 pukeuv Pro Tools TDM Systems (Mac) 6 04-24-2006 09:46 AM
recording a vocal with compressor plugin... how to avoid latency? Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 07-18-2003 10:21 PM
avoid latency.. sandman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-03-2000 04:41 AM
