Having some weirdness with the whole USB MIDI thing, and would like to bring back the MTP-AV.
Are there still drivers for this, and where can I get them? MOTU's site doesn't seem to have Tiger drivers for this. Note, this is the Serial model.
Mac Pro Dual 3GHz PT 20.9.1.123 MacBook Pro 15in, 2.3gHz,i7 Quad Core PT12.8.x |
I have some G4's (Dual 867's) using the Stealth Serial converter with Mbox LE systems & older MTP-AV serial.
Mac OS 10.4.8 PT's LE7.1 stealth web page |
I am using one with a Stealthport on my G4 (1.25 dual, PT HD 7.3.1 and OSX) for syncing to video. You use the driver for the USB version from the MOTU site. It works well in my setup, but I can't see how it would be an improvement if you are unhappy with USB midi interfaces since that is essentially what you are creating.
Colin Van Hattem Noizemaker Productions |
works fine mac pro osx 10.4.8 protools 7.2.1
from the motu site go to support > midi timepiece av > downloads > midi osx drivers etc, you may have to sign in at some stage http://www.motu.com/download/downloa...?product_id=16 |
"You use the driver for the USB version from the MOTU site. It works well in my setup,"
I didn't know that driver would work for the serial version? You used to have to download their driver, clockworks, etc to get it to work. I'll check it out. I've been told that serial transmission for MIDI is better than USB. Between the iLok, Trigger Finger, Keyboard, 2x2, etc and the USB hub, I want to see if there's a difference. "but I can't see how it would be an improvement if you are unhappy with USB midi interfaces since that is essentially what you are creating" I'd be using my Stealth port and no USB connections. That seems much different than using a USB connection? Steve
MIDI TIMEPIECE AV SERIAL PORT WITH PT 6.4.1 | cargrill | Pro Tools TDM Systems (Mac) | 1 | 04-08-2006 01:07 AM |
MIDI TIMEPIECE AV SERIAL PORT WITH PT 6.4.1 | cargrill | MIDI | 0 | 04-07-2006 11:42 PM |
MOTU Midi Timepiece AV Serial w/ OS X ??? | MLCirca | Pro Tools TDM Systems (Mac) | 4 | 03-14-2005 07:38 PM |
MOTU Midi Timepiece AV Serial w/ Mac OS X ??? | MLCirca | MIDI | 2 | 11-18-2004 06:26 PM |
G port serial midi timepiece AV OSX and 6.1 | cosmic fish | Pro Tools TDM Systems (Mac) | 13 | 10-01-2004 11:14 AM |
