Old 01-25-2000, 05:02 PM
midigeek midigeek is offline
Default Digi Init crash on G3 B&W\'s and G4\'s
I was hoping that ProTools 5.0 LE and the new DAE/DSI 5.0 would fix the lockup crash on the digi init every now and then but it did not. I have seen the 001 on a G4 do it and a G3 350 B&W with a PT/24 system also still crash with the digi init enabled.
When will it get fixed????
Thanks
Mike Stokes
Old 01-26-2000, 06:17 PM
sgerst sgerst is offline
Default Re: Digi Init crash on G3 B&W\'s and G4\'s
I second the above-
I shouldn't have to reboot my G4 30% of the time on start up because of a non-beta (ie "final" & "non fully working" init.
On the other hand- 5.0 LE w/AMIII is a welcome step in the right direction.
hint to Digi:
add a MIDI arpeggiator and -*cough* *cough* - VST COMPATIBILITY (yes- I know- the competition)- and I'll never go back to Vision or Logic/Cubase.
Allowing me to drag my hundreds of dollars worth of VST plug-ins into my PT folder would shut the door forever on the others' software... and I wouldn't look back.
[This message has been edited by sgerst (edited January 26, 2000).]
Homme Remixing
NYC
212-421-1860
Old 01-26-2000, 09:27 PM
AvidCS's Avatar
AvidCS AvidCS is offline
You've probably heard this before but I'll toss it out again just for clarification. In order to get the performance we require we have to reprogram the pci-bridge chip.
This is a known issue with the rev of the pci-bridge that Apple chose to put on the motherboard. They are very much aware of the problem. However, after extensive investigation unfortunately, there doesn't appear to be anything that can be done to completely prevent the crash when this parameter is changed.
Bob
[This message has been edited by DigiCS (edited January 26, 2000).]
Old 04-08-2000, 03:26 PM
Did this get fixed by Apple? As I just setup a G4 500 MHz and I have not seen it lock up yet. It came with OS 9.0.2.
Thanks
Mike Stokes
Old 04-10-2000, 07:19 AM
jaglance jaglance is offline
for what its worth, i have found that making the digi init load 1st (type a space in front of the name) makes a huge difference maybe 1 lock up in 12 - 15 boots.
G3 pro tools mix24 plus
Any luck with INIT driver for PTIII and G4's soundboy35 Pro Tools TDM Systems (Mac) 0 09-18-2002 10:56 AM
digi init dannypearson Digidesign Hardware & Software 0 12-10-2001 08:35 PM
Where to get Digi Init 3.2.2? Christo Beaver Tips & Tricks 0 10-18-2000 10:49 AM
Digi INIT 5.01 and Jam michael c Pro Tools TDM Systems (Mac) 1 05-29-2000 08:37 AM
digi init crash-move graphics card? DigiTechSupt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-24-2000 12:39 AM
