Instruments = Light PIP Aux I\\O digi002
Instruments = Light PIP Aux I\O Outboard Gear\ Bus\ digi002
What I’m trying to do is make my drum machine & Keyboard Hit the I\O bus To record into several tracks at once. I have Three outboard gear. Pre-Amp BBE Sonic, Aural Exciter. Example: Here Is my Set-up. Out board Gear is making Loop sends and return. 3-4\ 5-6\7-8. ins and outs of digi 002. Instruments going out\into Alesis ADAT 1-8 Light PIP into Digi 002. So I want to bus and record all my instrument sounds AT Once on each track using the outboard Gear loop sends and return I\O Aux To Tracks I know this could be done one track at a time. But How do you record several Tracks using the Bus and I\O for each track? I get a massage saying The H/w insert could not be made active because it’s output is being used by another active output or insert. Is their another way to get around this? This want I would like to see happen. Drums Machine set-up AUX Kick,on 1 with all the I\O gear being recorded into Track 1 AUX Snare-on 2, with all the I\O gear being recorded into Track-2 etc. etc. |
1394 Light on Digi002 Rack keeps blinking | doviedo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-15-2008 09:06 AM |
DIGI002 dead! light are on but nobody's home! | warrenbgalt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-06-2005 12:29 PM |
On-Air Signal/Light with Digi002 for rec session | Tinmar | Tips & Tricks | 1 | 09-26-2003 12:11 PM |
On-Air Signal/Light with Digi002 for rec session | Tinmar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-24-2003 06:41 AM |
Digi002/Protools and VST instruments? | daede7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-28-2003 12:58 AM |
