Type 11 Bounce to Disk error
When a bounce to disk is almost completed and the conversion process is starting (convert after bounce), I'm getting a Type 11 Pro Tools quit every time. No bounced files are created. It's happened twice now. I'm bouncing a 24/44.1 session to Redbook. Any ideas? I tried the Answerbase, but it's only mentioning OS 7.6 issues, which I'm not runnning. PT|24 MIX PT 5.1.1 OS 9.2.2 |
Re: Type 11 Bounce to Disk error
Anyone?
Try to convert during bounce
An error type 11 is a miscellaneous hardware exception error.
Apple's suggetions for troubleshooting. First off, trash these prefs: DigiSetup, DigiTest, DAE (the whole folder), Finder, Pro Tools. See if that clears it up. If you still have a problem, I would check your disks with as many disk utilities as you have (Apple's, Norton, DiskWarrior, TechTool Pro, etc.). If they check out, run DigiTest. Also, try maxing out your DSP if DigiTest claims your cards are OK. I've found that maxing out the DSP is the only true way to test the cards in some situations. DigiTest doesn't test everything on the card.
Try allocating more memory to the Pro Tools application as well as DAE. Type 11's are usually memory related.
Bounce to Disk issues and bounce to direct show error. | SeattleHank | Windows | 7 | 01-01-2014 12:41 PM |
Bounce to disk error - pro tools won't let me bounce the file! | HipHopHead | Pro Tools M-Powered (Win) | 1 | 05-14-2009 11:13 AM |
Bounce to disk error | beezle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-23-2008 06:38 AM |
PLEASE HELP....BOUNCE TO DISK ERROR | yunek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-17-2004 06:32 AM |
Type 2 error after bounce to disk?? | me | Pro Tools TDM Systems (Mac) | 3 | 06-23-2002 10:44 AM |
