It's ancient, I know, but I got it for almost nothing a couple of years ago, and now, in combination w/SSL UC1 plugin controller, I have a way to mix without looking at screens, and I love it.
The Command 8 is still working thru the latest versions of PT, I guess because of the simple midi communication it uses for connection. The LED meters don't work. They never did. Except I'm quite shure I remember them working before, but only slightly lighting up the -48db LED. But I didn't care, and just left it. I remember searching for a way to have them be "louder" without succes. Now, as I'm putting together a setup w/UC1 that lets me mix without looking at screens, I really could use the visual feedback of those meters. I did the Command 8 utility check, and the LEDs themselves are working fine, so I guess it's a question of PT meter data not getting to the C8. Everything else is working fine. Any thoughts? Anything at all.
Mac mini M2 base model, 16GB RAM. MacOS 13.2.1. PT Studio 2023.3. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Avid Control on iPad. |
Thinking again, I'm pretty certain that the LED meters worked with PT10, but I found them almost useless because only the bottom two would light up, simply because track levels were mostly under -15dbfs or so.
And I guess with all the new functionality of meters in PT, they didn't bother to preserve C8 compatibility. I tried "Pro tools classic" option in metering preferences, and all the other options, without any luck. Oh, well… ![]()
Sorry, but C8 end of support date was something like summer of 2017. I know for a fact it works with PT10 but current systems may have a problem.
Shure. But everything else works fine with the C8, nothing wrong except the meters. I'm using it quite extensively, more and more, now that I have the "virtual SSL console" functionality of the UC1.
HA!
I solved it! I uninstalled EUCon, restarted and Voi-la, PT feeds meter signals to the old C8! And with 'peak volume' selected in prefs, and input monitoring off, I get the visual feedback that I need on the Command 8. I haven't found the Control app on ipad to be anything for me, anyway.
I use the Command 8 in conjunction with the PT Control app and see the same behavior. The little meters on the C8 are almost worthless IMO, they're basically activity lights.
It's stated somewhere that Eucon takes over metering priority if used with another control protocol. So it's not just a C8 issue.
~Will |
Oh yea, I actually forgot it because there is absolutely zero reason to use ipad with my live rig. EUCON not installed.
![]() Quote:
Right. That's what I'm seeing.
Command 8 - Meters Not Showing in 2018.7 | Siegfried Meier | Pro Tools 2018 | 7 | 03-16-2019 10:12 AM |
Any suggestion? control 24 meters dead in PT work in Vegas mode | crizdee | ProControl, Control|24, Command|8 | 1 | 03-28-2013 03:29 PM |
Dead D-command | mark linett | ICON & C|24 | 1 | 01-14-2011 08:02 PM |
D-Command output Meters DEAD? | subwoof | Pro Tools TDM Systems (Mac) | 1 | 01-26-2010 02:19 PM |
Command 8 dead fader already?!! | mantaray | ProControl, Control|24, Command|8 | 4 | 08-24-2006 05:48 PM |
