Record through Eleven Rack Mic input?
I can't figure out how to record the wet signal when recording into the Mic input? I select Mic input in PT and it records the dry signal?
Re: Record through Eleven Rack Mic input?
Did you do this?
Create new track>input select Eleven Rack>(in 11R GUI window) select rig input to Mic>Record enable track.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
FYI, the "rig input" is what determines which physical input goes through the effect section of the 11R. This can be set to the guitar input, mic input, line in, or digital in. Whatever it's not set to will just function like a normal input, just like on the 003, etc.
so in PT input I select "Mic" and in the 11rack GUI I select "Mic" input?
That is correct. On the track you're recording to, select "mic". This ensures that your physical mic input will be recorded to that track. In the Eleven Rack GUI window, in the upper left corner, select "mic" also. This ensures that the mic signal will pass through the effects. If something other than Mic was selected, you would still be recording a dry mic signal to the track (because you have enabled that input for it), but it would not pass through the effects section of the 11R.
Only one thing at a time can go through the effects section. It's a good feature that these can be selected separately. For example, if you wanted to record your guitar playing and singing at the same time, you would create 2 tracks. One would be your vocals, set to the mic input, which would record straight to the track dry. The other would be the guitar input, and you would also select that to be the rig input, so it goes through the effects. |
Keep the PT input set to "Eleven Rig", as you usually would. Set the "Rig Input" in the GUI to "Mic".
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM Pro Tools 10.0.0 Ableton Live 8.2.1 RME Fireface 800 Eleven Rack |
What if I want to do this:
Guitar in/output to amp and record the mic'd up amp? I tried this once and just got a bunch of noise. |
You can send only one signal through the guitar rig processing chain. And in a DAW you can record the input to that chain and the (mono or stereo) output. You can record additional inputs at the same time (so you can record the physical mic, line-in and/or digital-in etc. in while also recording the wet and dry guitar signal). But that other inputs cannot use the Eleven Rack internal guitar rig processing chain if the guitar input is already using it. Darryl |
am i in the wrong place to set the "rig input" to mic if so how do i get to the rig input you are talking about?? thx |
On the first page, the very first option - highlight and select (SW1) Then use the lit knob to change the input.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Intermittent Eleven Rack input | Bridgepin | Eleven Rack | 7 | 04-24-2011 04:54 PM |
Eleven Rack not showing as input mac PT9? | microstudio | Eleven Rack | 6 | 03-15-2011 09:15 PM |
PLEASE HELP Eleven rack no input signal | voma79 | Eleven Rack | 5 | 03-02-2011 09:14 AM |
Eleven Rack..True Z input, | PMcC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-28-2010 08:56 PM |
