Old 01-27-2011, 07:31 AM
Hollow Body Hollow Body is offline
Default On Digi 002 with PT9 (windows) can you use 2 channels ADAT at higher sample rates?
I would have posted this on the LE forum but since I have PT9 now, I figured this was okay.
Quick question. I have Windows 7 , PT9.01, Digi 002.
Currently run my spdif with an apogee mini me. I have / use a digimax for my adat. (which obviously can't run higher than 48khz.)
My question is: Can I run the ADAT line as a 2 channel digital input at higher sample rates? (88.2 / 96) So if I got a 2 channel preamp with an adat optical out, would the digi 002 / pt 9 accept this at those higher sample rates? (Does apogee make one like this? Rosetta??) Or, If I got another Mini Me could I get a spdif to adat converter?
(When I'm in a project with higher sample rates it DOES show ADAT 1 and ADAT 2, so I'm presuming I can.)
Thanks!
Old 01-27-2011, 01:39 PM
Default Re: On Digi 002 with PT9 (windows) can you use 2 channels ADAT at higher sample rates
Why don't you just try it? I'm not sure, but its possible that it works fine. Or its possible that when you select the optical port=SPDIF, then maybe the RCA SPDIF port doesn't work. It will take all of 10 minutes to just give it a go
Old 01-27-2011, 03:34 PM
Hi. I can't try it because I don't have a preamp / A/D converter with ADAT optical out that goes up to 96Khz. But I might buy one if I knew it could do it. My digimax only goes up to 48khz.
Anyone else know?
Old 01-27-2011, 03:54 PM
JMS40 JMS40 is offline
From the 002 Getting Started guide:
The Optical I/O ports support sample rates of
44.1 and 48 kHz in ADAT Optical mode, and
sample rates up to 96 kHz in Optical S/PDIF
mode. The Optical I/O ports support 24-bit,
20-bit and 16-bit resolutions in both modes.
PT9 A&H ZED-R16, no playback at higher sample rates redbull Windows 10 09-20-2012 10:04 PM
ADAT, AES, higher sample rates Uli Rennert macOS 0 04-19-2011 08:23 AM
44.1 vs. higher sample rates Stacyodell Pro Tools TDM Systems (Mac) 88 09-22-2007 10:37 AM
Higher Sample Rates, Digi Interfaces, and ADAT Iain Graham Pro Tools TDM Systems (Mac) 5 03-03-2006 10:43 AM
any arguments against higher sample rates like 96? Tito Ricci Arballo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-08-2004 09:33 PM
