Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 10-18-2019, 05:54 PM
smashbox smashbox is offline
Default Control 24 expansion chasis
Hey! I've been running PT11 with an Apollo quad. Today I picked up a control 24 on the cheap to use as a controller since Neyrinck released v control. But have been thinking of setting it up as a B studio instead. I'm not familiar with this type of setup and I have a few questions.
The control 24 came with a 64bit expansion chasis with magma card.
It did not include the pci card that goes in the computer. Are these hard to come by?
Also, how exactly would this connect to pro tools 10? Does pro tools 10 simply run off the control 24 over ethernet?
I'm not really sure what I have here or how I would use the expansion chasis? it contains a magma card and some HD core and processor cards. Does it have to run off pt hd ?
I may end up using it as a v control but I'm just wondering what I'd have to do to set this up with pt10 as a second setup for now. Any info would be appreciated.
Old 01-20-2020, 11:44 AM
Default Re: Control 24 expansion chasis
The chassis doesn't have any connection to the Control 24. The expansion chassis is holding HD cards (which don't work with Pro Tools 11) so that you could run more cards than will fit in most towers. The chassis/cards should be fine with PT10 HD(or older) but you didn't get all the parts? There should be a card(PCI or PCIe) to go in the main computer, and a cable that connects between the card and the chassis Since you didn't get the card/cable, you'll have some searching to do. I have no experience with those but for sure, you'll need to know the exact model of the chassis so you can search for the right pieces. The Control 24 connects via Ethernet for control. If you want to use the preamps(most people don't), then you need to connect the line outputs(DB25 connections) to compatible IO boxes(second-hand 192's are a good budget option, but make sure they have analog IO. The 192 DIGITAL is not a good option here). In fact, a single 192 with an extra INPUT card would handle all 16 of the Control 24 preamps(but as I sad, few people like them)
expansion chasis help? JT916 Pro Tools TDM Systems (Mac) 6 04-28-2004 09:57 AM
Expansion Chasis for HD5 jerrahi Pro Tools TDM Systems (Mac) 1 08-12-2002 06:33 AM
expansion chasis robby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-19-2002 07:22 PM
Expansion Chasis ratz Tips & Tricks 3 03-27-2001 05:29 AM
expansion chasis loutunes Pro Tools TDM Systems (Mac) 6 01-05-2000 04:59 PM
