Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-02-2021, 04:06 PM
John McDuffie John McDuffie is offline
Default unable to trash preferences
Windows 10 - I have tried recommended procedure :
[Windows] R / %appdata% click OK / opens list of apps click "Look for another app on this PC" - opens file explorer / select Avid folder to open it /
(directory path is C:\Program files\Avid\ )
select Pro Tools folder, left click, select "delete"; processor monitor dialog opens and it begins deleting files and folders and then I get an error dialogue that says "cannot delete because a file or folder in it is open in another program"
It does this even if attempting to delete the folder is the first thing I do after starting the PC.
Old 11-02-2021, 04:13 PM
Top Jimmy's Avatar
Default Re: unable to trash preferences
That is most definitely not the path to the Pro Tools prefs folder. You may need to reinstall Peo Tools if you’ve been trying to delete that folder.
Follow the instructions located here.
https://www.sweetwater.com/sweetcare...erences-for-PC
James Cadwallader
Old 11-02-2021, 04:30 PM
That link is where I got the method I was following. What is the correct path to the Pro Tools preferences I need to delete?
PS I just ran Pro Tools, it seems to still be working correctly.
Old 11-02-2021, 04:38 PM
Top Jimmy's Avatar
You have to show hidden files first. The path is something like c:/Users/*you*/AppData/Roaming/Avid/Pro Tools
James Cadwallader
Old 11-02-2021, 04:39 PM
There is better documentation of what to do provided by Avid in the usual place.... the Optimization and Troubleshooting guides. But not so easy to find.
A mass of information: https://avid.secure.force.com/pkb/ar...oting/en367983
What you want is in here: https://avid.secure.force.com/pkb/ar...ide#delete_pro in the section titled "Delete Pro Tools Databases and Preferences".
And you should have read that guide as part of optimizing your system properly, if not then have a read.
Old 11-02-2021, 04:43 PM
Trashing prefs is significantly easier if you use guitardom's handy utility available here:
https://www.pro-tools-pc.com/
scroll down to the link for Trasher 3 and make a donation. Its worth every cent
Old 11-03-2021, 03:39 PM
Thanks Darryl Ramm - apparently the recommended [Windows]R > %appdata% > was directing me to the wrong path; thanks for nothing Sweetwater! I am going to add the correct folder to my quick access list.
Thanks a bunch!
Old 11-03-2021, 04:46 PM
Great you got that sorted out. Yes I cringed when I saw how Sweetwater was using that variable. I'd also agree with Dave, that getting the Trasher app is a good idea.
How To Trash Databases & Preferences Becharax Pro Tools 11 0 06-23-2013 01:22 AM
Trash Preferences March314 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-21-2006 04:50 PM
Why trash preferences and what J-P-78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-06-2004 05:17 AM
How to Trash System Preferences ? mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-02-2004 12:07 AM
Cant trash preferences for 6.0...help please.. cerebus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-30-2003 12:13 AM
