Old 05-29-2009, 06:06 PM
alance alance is offline
Default Luanch failure due to shared library
iMac g5, 10.3.9, 6.4 le, mbox
new install after work was done on computer but worked a couple of times since and worked for years prior but now I get this. Search has led to a thread on EQIII incompatability but it's the exact same software from original disks that has worked for 6 years. Any Ideas?
Old 05-29-2009, 11:01 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Luanch failure due to shared library
If the error message contains more than just Launch failure due to shared library, the additional wording may help isolate the problem.
You might need to try a clean uninstall and reinstall of Pro Tools:
Answerbase
The Pro Tools LE 6.4 installer and 6.4cs9 update can be found here:
Pro Tools LE 6.x Downloads
Administrator
Application Launch Failure - shared library error dlehrich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-26-2007 03:38 PM
Shared Library Error - on OS 10.4.9 digimutt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 06-25-2007 10:57 AM
Application launch Failure -- shared library error digimutt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-25-2007 10:20 PM
PT Launch Failure; "Shared library error?" rickymix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-04-2007 06:31 PM
Launch Failure "Shared Library Error" - help? rabbitears 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-09-2005 07:02 PM
